to cam or not to cam??
Old Feb 24, 2010 | 10:06 AM
8dxhatchy8's Avatar
Default to cam or not to cam??
so i was thinking of putting an A6 cam in my rex, it has a b2 already multiported...would i see any significant gains at all? or is it not worth doing?? and no i dont want to do a B series swap at this time...thanks guys.
Old Feb 24, 2010 | 11:00 AM
EFRue57's Avatar
Default Re: to cam or not to cam??
yes, from what i've read before, adding the si cam adds about 10-15 hp. idk if it is just the cam itself that does this or the cam w/ the mpfi conversion but either way, still a decent upgrade.
Old Feb 24, 2010 | 11:31 AM
8dxhatchy8's Avatar
hmmm...im really considering it then, i have basically every other bolt on, including an si tranny..
Old Feb 24, 2010 | 02:13 PM
88CiViCtechy's Avatar
How much does this cost?
To me it doesn't seem like building the d series is the way to go with the cost of the b series these days.
Regardless, 10-15 hp is good gains from a factor cam.
Old Feb 24, 2010 | 04:13 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
10-15 HP from a camshaft on a essentially stock SOHC??? That is laughable... you don't really see those gains from a stock DOHC VTEC engine with a cam change. Even if you are talking about a VTEC SOHC (I know you are not though) with a BHP of 127, 10-15 HP would be an 8-12% or so increase in power. Then, if you look more towards the HP of your SOHC non-VTEC, you are talking a 10-15% power increase. You are just not going to see those types of gains from an essentially stock engine.
Even if the head had a major port and valve job done, Honda heads flow extremely well from the factory. There are tons of informational sites on this and I am NOT going into detail. If you were to see any true gains, you would need it to be DYNO tuned as well.
Look at this B18C with Skunk2 Tuner Cams Stage 1...
http://www.skunk2.com/mm5/merchant.m...de=305-05-0140
A 12.3 HP gain on a B-series VTEC... There is a reason why they do not show any DYNO results for a SOHC...
If you want more power on a stock SOHC, go turbo or nitrous (you are still talking about a maximum of around 40-50% more HP on a stock setup). Even if you go high compression the end result is still dismal... unless you are willing to shell out some serious coin.
Do what you want, it is your money.
Old Feb 24, 2010 | 05:40 PM
8dxhatchy8's Avatar
well first of all its not going to cost me anything cause i can get the parts for FREE and i am going boost in the long run anyway so....
v4lu3s
Feb 17, 2017 04:58 AM
spotscivic
Jun 20, 2007 07:45 PM
civicpimp
17
Aug 12, 2005 10:45 AM
stockgreencivic
Mar 2, 2003 09:12 PM
W0oT
Oct 4, 2001 10:07 AM
