swap woes
Old Feb 24, 2010 | 09:03 AM
tony7626's Avatar
Default swap woes
i have a 90 crx si. with a 91 b16a and what i was told is a j1 tranny. im swapping in a 01 Gsr, it has a clutch, but no tranny. my first plan was to just reuse my tranny but seeing how its older anyways i wanted to get a newer hydro tranny. i have heard multiple times that the 89-91 intermediate shafts are different and the clutch would need to be swapped. does anyone know if the axels i have will work with a newer hydro trans? or would i need to get everything new
Old Feb 24, 2010 | 09:27 AM
hatchet_honda's Avatar
Default Re: swap woes
what intermediate shaft do you have? match the axles to that. so pretty much use your same axle setup. i have a 95 gsr hydro trans and im using 93 teg axles and halfshaft
Old Feb 24, 2010 | 11:25 AM
EFRue57's Avatar
as for the clutch, you need to buy the clutch disc for the tranny. so if you are gonna be using a gsr tranny, get a gsr clutch disc. the pressure plate from any b series will work fine so if your old one is still usable and you want to save some cash, just reuse it.
Old Feb 24, 2010 | 01:39 PM
tony7626's Avatar
im not really sure it was swapped before i got it. is there any way to tell what shafts i have?
Old Feb 24, 2010 | 01:54 PM
D16SiHatch's Avatar
if the intermediate shaft is female with a male axle then you most likely have 90-93 teg parts. if the intermediate shaft is male then they are likely 94-01 teg axles.
xlusiveracer
19
Feb 22, 2007 02:04 PM
4thgenman
Mar 15, 2006 02:39 PM
dEd hOm E
Mar 6, 2005 06:20 AM
AgentJam
Nov 8, 2003 01:52 PM
