Suspension & Brakes Theory, alignment, spring rates....
Need Help ASAP for 97' Civic Upper Control Arm
Old Feb 24, 2010 | 07:16 AM
jvang91's Avatar
Icon3 Need Help ASAP for 97' Civic Upper Control Arm
After changing my upper control arms. i took it our for a test drive, but there was a problem with the steering. It turns realllllllyyy easy and drags you to the direction where i was turning so i had really no control over car. When you let go of the steering, it doesnt release itself to go straight again. I didn't touch nothing else on the car except taking out the upper control arm and replacing it. Does anybody have anything that can solve my situation?
Old Feb 24, 2010 | 09:32 AM
gabebauman's Avatar
Default Re: Need Help ASAP for 97' Civic Upper Control Arm
Are these stock uca's or adjustable aftermarket uca's? It's possible that you put them on backwards. There is a Left and a Right.
Old Feb 24, 2010 | 09:35 AM
jvang91's Avatar
Yes, they are just oem. I had camber kits before, but i wanted to change it. So now that i changed it, it started turning weird. But if you think i put it on backwards, ill try changing them today to see if it was because i had them on backwards. Thanks
Old Feb 24, 2010 | 09:38 AM
gabebauman's Avatar
Check to see if they are on the correct sides of the car before you remove them. There should be an L stamped on the driver side and an R stamped on the passenger side.
My guess is that your alignment is off now.
Old Feb 24, 2010 | 09:52 AM
jvang91's Avatar
I just checked and yea, they are correctly placed. To mention, my alighnment was off before. but wasnt as bad as it is now.
Old Feb 24, 2010 | 10:16 AM
jasoncanseeoh's Avatar
Def. check your alignment at a shop.
Old Feb 24, 2010 | 10:18 AM
gabebauman's Avatar
Yeah...you're gonna want to take it in for an alignment asap. Have them set the toe as close to zero as possible.
Old Feb 24, 2010 | 12:03 PM
jvang91's Avatar
Thanks guys =]
luckybuddha
Mar 16, 2012 04:11 AM
Halo
Nov 7, 2006 07:52 AM
xamraci
Sep 25, 2006 09:24 PM
tealbubble
25
Jan 18, 2005 08:20 AM
