D15B JDM o2 help
Old Feb 23, 2010 | 07:59 PM
birdtc1's Avatar
New User
Default D15B JDM o2 help
hey everyone i just put in a JDM D15B vtec in my usdm 95 civic lx and im getting a code 1 for the o2 i had to use my old header becuz the o2 was a one wire and mine had 4 what do i do is there a way to fix that let me know thanks
Old Feb 23, 2010 | 08:15 PM
D16SiHatch's Avatar
Default Re: D15B JDM o2 help
so you don't have the o2 plugged in then or what?
Old Feb 24, 2010 | 08:24 AM
nothing_shocking's Avatar
What ecu are you using?
Old Feb 24, 2010 | 08:27 AM
andoxviii's Avatar
If you are using the Japanese-spec P08 ECU, you will need to use the 1-wire oxygen sensor. If you are using a North American-spec ECU, you will need to use your old oxygen sensor.
Old Feb 24, 2010 | 10:02 AM
tlarimer's Avatar
OK, not true on using the 1-wire o-2 sensor. If using the P08 ecu, you can use the USDM 4 wire o-2 sensor, the 1-wire that the ecu needs is there and hooked up. The other wires are there, just not doing anything. I did lots of research before swapping in my D15B Vtec yrs ago and ran it with a P08 ecu and 4-wire o-2 sensor and never had one bit of problems. As this was the recommended solution to not being able to get the correct 1-wire o-2 sensor here in the states.
Old Feb 24, 2010 | 10:06 AM
andoxviii's Avatar
My D15B VTEC swap came with the 1-wire oxygen sensor. I thought they all should...? The OP probably has both.
The OP should probably tell us which ECU he is using...
Old Feb 24, 2010 | 10:13 AM
tlarimer's Avatar
Yes, you are right, the D15b should have the 1-wire o-2 sensor, but most times they are damaged when we get our engines. The use of the 4 wire o-2 sensor as a replacement is fine, since both ecus use the same pin for o-2 signal wire. The main difference is the USDM has a heater in the o-2 sensor, where as the JDM doesn't. So you can use a 4-wire on either the P08 or P28 ecu.
CXtypeR
Mar 13, 2007 07:26 AM
racingant
12
Nov 11, 2005 06:41 PM
crxludeT66
Mar 27, 2003 05:36 AM
gtpilot
Dec 12, 2002 12:27 PM
See Are X
Sep 3, 2002 10:38 AM
