Power Steering Gone? Just swapped tranny..
Old Feb 23, 2010 | 03:56 PM
avargas28's Avatar
Icon6 Power Steering Gone? Just swapped tranny..
...so I just swapped in a used cable tranny on my DA because my old one was worn. Everything runs fine except it appears my power steering is shot. It's a pain to turn at a stand still and at slow speeds.
Is it my power steering or did we tighten something too tight? It worked fine before the switch.
Edit:
Duh, was looking in the wrong reservoir. It was the fluid. Put in a bottle of Honda fluid and I'm good. I'm a dumb ***.
Old Feb 23, 2010 | 04:25 PM
TheAsian's Avatar
Default Re: Power Steering Gone? Just swapped tranny..
Did you check the belt?
Old Feb 23, 2010 | 06:13 PM
avargas28's Avatar
Belt is fine. It was working prior to switching the tranny. So I'm wondering if it may be an axel or we just tightened something to tight or something.
Old Feb 23, 2010 | 11:43 PM
Honda_ThuGZ's Avatar
did you guys disconnect the PS lines on the speed sensor? Fluid might have leaked out
Old Feb 24, 2010 | 09:07 AM
seanbev24's Avatar
X2 that was my first thought
Old Feb 24, 2010 | 10:28 AM
avargas28's Avatar
These 2 hose lines, right?
http://i45.tinypic.com/6928hx.jpg
Yeah, we had to unplugg two lines to fully remove the tranny. Red fluid leaked out which i initially thought was tranny fluid.
Old Feb 24, 2010 | 12:00 PM
mouab18c1's Avatar
No they aren't tranny fluid. Check your Power Steering resevoir tank to see visually if the power steering fluid is low before adding more.
stevevang
Nov 2, 2015 03:47 PM
busyychild
Feb 22, 2008 02:30 PM
Lauj87
Nov 28, 2006 12:58 PM
killa_lude
May 10, 2004 08:16 PM
