need help rebuilding a d16z6 a lil lost.
Old Feb 23, 2010 | 01:58 PM
the hand of god's Avatar
Default need help rebuilding a d16z6 a lil lost.
ok so i bought a 1993 del sol, d16z6, and it needs new valve seals, and the kids b4 me snapped off the valve cover bolts so i think i am going to buy a new head. can i do this with out messing with the pistons? and what would i need to put a bigger cam in? i dont no whats the cheapest places to go to. thanks. and whats a easy way to add hp? trying to keep it cheap haha.
Old Feb 23, 2010 | 02:17 PM
Top Ramen's Avatar
Default Re: need help rebuilding a d16z6 a lil lost.
If the car is still drivable, I would get another head to build. D series heads can often be found pretty cheap. If the other head is in good shape, all you need to run a larger cam is new valve springs. If it needs work, at least you can still drive your car while it is being done. IMHO, Bisimoto is the place to go for a D series cam.
If you have the money, a good valve job is always nice to do. It will give you 30-50% of the increase a full head porting package would give you, but costs significantly less.
And, yes, you can do this without messing up the pistons.
Best of luck with your project.
Old Feb 23, 2010 | 10:55 PM
ok cool, im am keeping it off the road for like 3 months to get all the work done to it, it needed alot of body work. and ok thank you. so i dont need to change the pistons or anything if i switch heads? my dad said i would. i hope not lol
Old Feb 24, 2010 | 06:48 AM
Top Ramen's Avatar
No. You pull the head on and off without even touching the pistons. However, if you are not absolutely sure its the valve stem seals, this would be a good time to freshen up the short block with new rings, etc.
Old Feb 24, 2010 | 08:12 PM
ooo. and hey guys... do i have to redo my timing if i get new heads?!?!
danielh5656
14
Jul 28, 2011 04:08 PM
singlecamkilla
Northeast (Sales)
Mar 7, 2006 08:37 PM
Matthew2785
Sep 28, 2005 04:38 AM
jdm_eg
Aug 4, 2004 01:01 PM
DelSlow93
Jul 25, 2004 12:19 AM
