squeaking timing belt
Old Feb 23, 2010 | 09:07 AM
acmoc's Avatar
Default squeaking timing belt
Hi guys,
My timing belt has started squeaking , but only in the mornings when it's cold.
It has less than 5 k miles on it.
Is this normal or Should I replace it.
Thanks
Old Feb 23, 2010 | 09:26 AM
B18B1-Crx's Avatar
Default Re: squeaking timing belt
Originally Posted by acmoc
Hi guys,
Thanks
WTF???haha
Most likely isn't your timing belt.
What motor do you have?
Timing belts have teeth so they dont slip and squeak.
it could be Alternator/power-steering/or idler pulleys etc.
Old Feb 23, 2010 | 09:39 AM
EFRue57's Avatar
Originally Posted by B18B1-Crx
WTF???haha
x2
Old Feb 23, 2010 | 09:40 AM
acmoc's Avatar
WTF???haha
I have a 1991 honda crx si
sohc zc
i do have an aem cam gear +1 degree
and AEM alternator pulley
Maybe my alternator belt is too loose
Old Feb 23, 2010 | 09:46 AM
jonnyt1130's Avatar
WTF???haha
X3 if your timing belt was "squeaking," that means its slipping which doesnt occur because the teeth prevent that from happening. (sometimes in bad instances it fails) , and if that was the case, your timing would be S.O.L. and so would your motor after bending some valves.
Old Feb 23, 2010 | 10:19 AM
StandingCRX's Avatar
i had the same problem on my CRX with my serpentine belt. squeaky when it was around freezing in the morning but it was fine after the engine warms up. what i did was i tightened the serpentine belt even more when the car had been sitting for a couple hours and it stop squeaking. so try that first before accusing the timing belt.
Last edited by StandingCRX; Feb 23, 2010 at 10:23 AM. Reason: ellaborated on solution
Old Feb 23, 2010 | 01:22 PM
acmoc's Avatar
Whats the serpentine belt?
Old Feb 23, 2010 | 04:02 PM
serpentine belt aka alternator belt. its the book definition for the alternator belt.
Old Feb 24, 2010 | 07:07 AM
acmoc's Avatar
Oh, I checked that, it's really tight.
My manual says 6 mm freeplay, there's only about 3-4. Could t be too tight?
Old Feb 24, 2010 | 07:37 AM
B18B1-Crx's Avatar
yea, i would loosen the belt.
My Alternator belt was so tight that my alternator seized up and locked up destroying the belt and causing smoking and the motor to stall=[
so i would loosen it asap.
it started out by squeaking at first of course.
Old Feb 24, 2010 | 07:39 AM
EFRue57's Avatar
a serpentine belt is a belt that runs multiple components, such as a chevrolet v8 where one belt runs the alternator, a/c compressor, power steering pump ect. when it is one belt that runs one component, it is referred as the "component" belt, ie : alternator belt, power steering belt, a/c compressor belt, ect.
Old Feb 24, 2010 | 08:06 AM
grog's Avatar
Dont be so quick to rule out the tuning belt, timing belts can sqeak, the belt runs over the flat "wheel" of the tentioner, which is where the sqeak could come from. but definitely start with the alternator belt first.
Heres a thread with a sqeaking timing belt https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/squeak-timing-belt-question-2717460/
Old Feb 24, 2010 | 08:23 AM
AndThenYouSay's Avatar
you should have a tensioner pulley, its got bearing, they could whine, doubtfull though. more likely is your external belts. pull one off before you start the engine, and it might go away. or you could use the paper towel trick and listen to different parts of your engine to see which pulley is making the noise. remember it may be the belt slipping, or a component it's self squealing.
GSRpower
Dec 30, 2002 08:16 AM
GSRaCeRbOI
Oct 22, 2002 06:34 PM
