need help asap!!!! pllease
Old Feb 23, 2010 | 06:57 AM
erictheboss253's Avatar
Default need help asap!!!! pllease
Two lugs snapped on my 88 ef sedan in front, I pulled everything apart but couldnt get the lugs all the way off then was told hub assy has to be pressed apart, I have a 95 integra assy with new lugs chilln, would that fit or do I have to get another assy from a 88 ?
Please help this is my daily driver and my work is an hour commute
Thanks, Eric
Old Feb 23, 2010 | 07:22 AM
Default Re: need help asap!!!! pllease
Well waste of a thread found out it won't work, but junk yard has a replacement pulled ready to go for 45
Old Feb 23, 2010 | 07:34 AM
jlicrx's Avatar
save the $45 - just replace the studs - go here:
http://www.fourthgenhatch.net/wheelstud.html
Old Feb 23, 2010 | 07:43 AM
I have lugs chilln in my glove box, would hubs from a 90-91 teg fit?
Old Feb 23, 2010 | 07:57 AM
Thank you, ima try that hopefully my harbor frieght big as grinder works haha, if I knew/ thought of this I would have brought it all to work,
Old Feb 23, 2010 | 08:21 AM
EFRue57's Avatar
are you guys serious with that????? damn, ghetto. there are ways to make things work and ways to make things right. do it the right way man.
Toe_fur
Transmission & Drivetrain
Nov 8, 2012 06:20 AM
marauder228vw
Mar 1, 2012 08:10 AM
Freshdot
Feb 27, 2011 01:59 PM
eats06702
May 17, 2007 05:25 AM
BigaCustoms
Sep 6, 2004 09:13 PM
