installing cams. Please help!
My question is; Is it necessary to measure valve to valve clearances when installing cams?
I currently have an H23 block w H22 head running in my car with stock cams but want to up grade to skunk2 stage2 cams.
If I do have to, is it possible to do it with out removing the head?
Also what degree should I place the cams after installing?
Thanks in advance
Thanks in advance
Only if they are fairly large or you anticipate using cam gears to move them around a lot. You should call the Skunk2 tech people and ask them, but with stage 2 cams, I don't think that should be a significant issue.
SIvic bob.tec
Aug 13, 2012 08:36 PM
The Si
Feb 22, 2007 03:17 PM
