Is this kind of camber kit safe?
I'm looking at these new style camber kits for the front
They are not your ordinary "U" style camber kit
http://i57.photobucket.com/albums/g2...01BUSET-L2.jpg
Are they any good?safe?
That's actually the original "style" camber adjusters for double wishbone Hondas. I would say they are worse because they are very difficult to get both bolts adjusted the same. If you're not careful you'll end up with whacked out caster and the adjuster bolts could bind.
I doubt you need a camber kit for a street car. Just have the toe angles adjusted to spec and you should be fine.
i had those a few years back. absolutely horrible. impossible to adjust and the bushings wore out in no time causing all kinds of banging noises in the front end.
if you need a adjustable camber kit stick to the skunk2 style for the front.
