Suspension & Brakes Theory, alignment, spring rates....
What kind of bushings to use with BLOX LCA
Old Feb 22, 2010 | 05:23 PM
NUISANCE's Avatar
Default What kind of bushings to use with BLOX LCA
I am looking to buy at set of Blox LCAs but want to replace the bushing right from the start. Do I replace them with stock bushings? Will energy suspension bushing work also?
Old Feb 22, 2010 | 06:05 PM
jt223539's Avatar
Default Re: What kind of bushings to use with BLOX LCA
Just buy these. And they press in and out pretty easy.
http://www.jhpusa.com/store/pc/viewP...idcategory=288
CplNet's Avatar
i'm 80% sure it's the same bushing.
btw you talking about rear lca ? energy doesnt have it i think...
go prothane! i ordered mine rear lca prothane bushing this week
Old Feb 22, 2010 | 06:06 PM
CplNet's Avatar
the photo looks like the oem bushing.. if thats right, oem/energy/prothane is fine
Old Feb 22, 2010 | 09:10 PM
racebum's Avatar
energy does make lca bushings. you can get them for oem arms or just buy function 7 which uses them in there arms
Old Feb 22, 2010 | 11:10 PM
Davidss's Avatar
I tried using energy suspension bushing in blox lcas and they did not fit. I tried to do the same thing that you are planning, buy cheap LCAs and put nice bushings in them. I don't think there are any off the shelf parts that will work. The blox's bushing diameter is the same as stock but the actual control arm is narrower so any poly bushing made for a stock LCA won't fit correctly.
Old Feb 23, 2010 | 05:49 AM
phunhaus's Avatar
Why would you buy them just to immediately replace the bushings? That seems asinine.
Old Feb 23, 2010 | 05:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Just get F7 arms. They come with specially made ES bushings, and if those bushings ever wear out, F7 will just send you another set.
Old Feb 23, 2010 | 10:21 AM
phunhaus's Avatar
QFT.
Old Feb 23, 2010 | 12:34 PM
racebum's Avatar
if the diameter is the same use a cut off wheel, grinder or razor knife and cut to fit.
Old Feb 23, 2010 | 01:40 PM
GagnarTheUnruly's Avatar
Hardrace is another option, as is OEM.
Old Feb 23, 2010 | 11:53 PM
Davidss's Avatar
For myself I already had a complete bushing kit and wanted a to switch LCAs to save a few pounds. If I could put the bushings into a set of $69 ebay LCAs it would be almost as good as a $200 premade alternative.
Yes the hole diameter is the same. But the actual LCA is narrower, so to make it fit you would need to enlarge the shoulders of the bushing.
boostinEJ8
Suspension & Brakes
Sep 12, 2013 09:13 AM
SlammedEG6
10
Feb 4, 2010 11:42 PM
philosofy1
12
Oct 29, 2007 01:08 PM
redman223
Suspension & Brakes
Aug 8, 2007 02:19 PM
sicegcivic
Mar 2, 2006 07:22 AM
