Cruise Control 93 Accord EX
I don't know how to fix my cruise control. The dash lights work when I press cruise 'power switch' on the dash and 'set decel' switch on steering wheel but still no cruise. Anyone have any trouble shooting guides/checklists available?? Road trip to cali in 1 week, need that cruise!
Check the cruise fuses in both fuse boxes. Make sure the brake pedal switch isn't activated. Check the cable from the cruise servo to the throttle. Make sure your speedo is working. Check the vacuum lines running to the servo. Check the electrical connector and all wires from the servo. Post if you have any engine problems. If all else fails, you can test the cruise wires at the ECU while someone is driving to see if it is sending a signal to the cruise servo.
ophdehEEzY
Jun 26, 2003 05:12 AM
