Suspension & Brakes Theory, alignment, spring rates....
92 civic rotor/caliper stamp?
Old Feb 22, 2010 | 03:50 AM
kct01's Avatar
Default 92 civic rotor/caliper stamp?
I'm trying to figure out which brake set up I have on my car. I didn't do this conversion so I don't know which one it is. I took the wheel off and I saw it stamped ad 51 21 13? any input would be great thanks
Old Feb 22, 2010 | 07:06 AM
roastbeefrichie's Avatar
Default Re: 92 civic rotor/caliper stamp?
to determine the brake set-up on your 5th gen 92 civic, you'll need to remove the front rotor and measure it.
DX knuckles & calipers w/ 9.4" front rotors (available 88-00 civic)
EX knuckles & calipers (uses a bigger brake pad) w/ 10.3" front rotors
Old Feb 22, 2010 | 10:56 AM
kct01's Avatar
okay I bought ebc slotted and drilled 9.4 and 99-00 si rear rotors(they all should fit!?)with green stuff pads. What fluid should I go with? I am going to be doing alot more of 1/4 mile tracking.
sshiny007
Dec 17, 2009 10:48 AM
BubbaHoTep
Suspension & Brakes
Apr 6, 2009 05:40 AM
1SikEagle
Oct 20, 2008 07:26 PM
lonefuzzy79
May 31, 2006 02:14 PM
