Water in Driver's Floorboard
Old Feb 21, 2010 | 03:24 PM
C_Rock77's Avatar
Default Water in Driver's Floorboard
I've got water pooling in the Driver's floorboard. What's usually the culprit on this?
Old Feb 21, 2010 | 03:37 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Water in Driver's Floorboard
Helps to know the car.....
For a 94-97 Accord it's generally a clogged AC Drain.
Old Feb 21, 2010 | 03:41 PM
C_Rock77's Avatar
LOL. Sorry, forgot you guys aren't mind readers . I apologize!
It's a 95 EX Accord.
There has been quite a bit of rain, today, and this water just showed up today.
I haven't been running the AC, so don't think that's the culprit.
Old Feb 21, 2010 | 03:48 PM
Well you've got a few areas, do you have the plastic fender linings in? I've had worn rubber plugs let water sprayed up by the tires in. You can also hose the car down on the outside of the door and see if rubber seals around the door are loose or not working right.
Old Feb 21, 2010 | 03:52 PM
C_Rock77's Avatar
Well. Here's the situation. I had loaned the car to a friend. When I picked it up, I didn't see signs of the water in the floorboard. I drove it, and the days were dry. It rained today, and water showed up in the floorboard. It was enough that when I opened the door, I could SEE where the carpet was soaked.
What would you think this might be from? Door Seals?
You're talking about the ones that go around the door?
Old Feb 21, 2010 | 04:06 PM
Holy crap, that does sound bad.
Yeah the rubber seals around the door itself and the door frame on the car. Make sure they are not damaged.
BoaConstrictor
Sep 14, 2015 03:24 PM
thekid2390
Jun 30, 2013 12:15 PM
marrieda97accord
Jul 6, 2008 12:06 PM
BiG_DeE
Jun 13, 2008 05:00 PM
Mayorseed
Nov 1, 2007 04:51 AM
