Ticking noise from clutch....
whenever i release my clutch halfway there's a ticking noise (one loud tick) coming from the passenger side... its really weird and its been happening since i replaced my clutch.... what could it be and should i fix it?
I noticed the same roblem in my 2000 civic si it only happend in first gear for a while now it happens 1 2 and 3 not all the time though its wierd
any ideas anyone thanks
did u torque the flywheel bolts and the clutch bolts back to specs? my friends some how rattled loose and sounded like that then it got alot worse. make sure its not an exhaust leak to alot of times exhaust leaks make tickin sounds but i would think it would do it all the time. hope this helps. make sure the flywheel shield under the motor by the oil pan is tight too.
beoy9
Transmission & Drivetrain
Aug 23, 2008 01:04 PM
