quick question about sealers for the bodymen on ht
I plan to use ppg omni sealer/base/clear on a small project. If i were to use a different company's high build primer under the ppg sealer and topcoat, should that have much affect on my top coat after a while? bubbling/discoloration etc
What about using a different companies epoxy under the sealer and top coat?
Thanks
Thanks
as long as the primer is catalyst hardened, youll be fine with whatever sealer you use. If you use lacquer primer, than you may run into problems. Stick with decent stuff and youll be fine.
ShakesTheKlown
Jul 4, 2003 01:35 AM
