have some extra hoses
Old Feb 21, 2010 | 09:36 AM
crxjarred's Avatar
Default have some extra hoses
Ok i have a d16a1 in a 90 crx hf have been having lots of small problems and now i get to mess with the vacuum hoses and i am now down to the last three that are in the back of the intake manafold i have tryed to find a diagram and have had no luck can someone help.
Old Feb 21, 2010 | 10:51 AM
grog's Avatar
Default Re: have some extra hoses
what car did the D16A1 come stock? Search this parts catalog you should be able to figure it out.
http://www.hondapartscheap.com/southbay/jsp/home.jsp
Old Feb 21, 2010 | 11:01 AM
crxjarred's Avatar
the engine came out of a 89 integra and its not on the list i have tryed serching for the diagrams and havent found much
Old Feb 21, 2010 | 11:09 AM
grog's Avatar
did you try an acura catalog ? http://www.acuraoemparts.com/delray/jsp/home.jsp
Old Feb 21, 2010 | 02:42 PM
crxjarred's Avatar
i cant figure out much there i was wanting to see a diagram of the intake manafold
Old Feb 21, 2010 | 07:05 PM
hatchet_honda's Avatar
shouldnt the large one to the right be hooked to the brake booster?
Old Feb 21, 2010 | 08:27 PM
nurburSTIG's Avatar
Hmmm.
Old Feb 21, 2010 | 08:32 PM
chivid's Avatar
thats correct. the second one you can block off. no use unless your using your evap purge. and the first one on the left i believe goes to your fuel pressure regulator or the tall-can looking canister that is on your left side of your eng compartment.
Old Feb 22, 2010 | 01:32 PM
crxjarred's Avatar
well if you mean the charcol canister then there is alredy one going to it from the throtal body and i have another hook up for the brake booster but if i have nothing else that needs to be hooked up then i can plug all these up and not have any problems and also i have a idleing problem i have changed my idle control valve and fixed my hose problem then what could be causing my idle problem?
Old Feb 22, 2010 | 03:46 PM
chivid's Avatar
does it have a fast idle valve on the bottom of the throttle body ? if yes, take the intake pipe n look inside the throttle and you should be able to see a hole inside. put your finger on the bottom hole and it should change your idle.
Old Feb 22, 2010 | 07:31 PM
crxjarred's Avatar
is it the whole thats dug into the bottem of the inside?
Old Feb 22, 2010 | 09:28 PM
chivid's Avatar
yeah.
Old Feb 23, 2010 | 06:18 AM
jlicrx's Avatar
hook up the vacuum lines same as the DOHC ZC - cap off the nipples on the back of the intake manifold - they go to things you don't need that were on the firewall on the Integra - the line from nipple on the left in your picture goes to the idle up valve - the one on the right also goes to the idle up valve - the smaller one in the middle goes to vacuum tank and tees off to the resonator control solenoid valve - this is the ZC vacuum diagram:
this is the 89 Integra D16A1 vacuum diagram - the items on the firewall which aren't labeled are, from left to right:
MAP sensor
purge cut-off solenoid valve
idle up solenoid valve
idle up valve
vacuum tank
jodyboy
Jan 2, 2013 11:56 AM
crazykamper
Dec 16, 2006 01:02 PM
sCeRaXn
May 5, 2003 01:36 PM
