how much to rebuild trans??
94 eg. b16. gsr trans.
think syncros are bad. guess gotta have trans dropped and looked at. what i wanna know is, how much should i expect to be charged to rebuild trans?
thanks for any help
thanks for any help
in most cases it costs the same as getting good used one i had the same issue and just got a b16 si trans with 44000 miles on it for 650, but i know the guy to so some trans are PRICY
anyone sell rebuild kits with everything id need for rebuild?
your last statement is why i think i wanna stay away from buying used trans. never know what im gonna get.
im sure everyone will say trans is good, no grinds, no pop outs, no issues.
but how do you know?
kid in pa had a gsr trans for 450...never know if its good or not.
dont wanna do this job twice.
didnt want to buy car and need to dump money into trans but seems like thats what im gonna have to do.
carbon 390
now question is, does this kit include everything needed for rebuild??
http://rover.ebay.com/rover/1/711-67...d=170356320324
http://rover.ebay.com/rover/1/711-67...d=170351073449
if kits dont include what else is needed?
i ask because i dont know man.
23431-P80-V00 GEAR, COUNTERSHAFT SECOND 1998 INTEGRA 110.90
23521-P21-315 SLEEVE SET, SYNCHRONIZER (1-2) 1998 INTEGRA 411.47
23451-P80-V00 GEAR, MAINSHAFT FOURTH 1998 INTEGRA 115.42
Assuming it really isn't the linkage that the problem (which I still suspect it may be) you will most likely need the above plus the 4th gear sleeve set which I can't seem to find a listing on.
think its worth trying to replace slave?
all day today when i go to car and try for gears, only 135
need this car fixed not sitting in driveway.
dont think i will take chance of buying a used trans, again for fear of unseen problems
if i should try to do slave, what do i need to do to do job the right way??
im not much of a mechanic but if theres a chance that can help maybe ill attempt it.
just went out and tried for gears, only tops
looked under car and think i see a spot where there may be a leak. kinda in the middle of car, behind motor. that area of car.
trans seal was done. so i figured i shouldnt have leaks under there??
