86 CRX 5 Speed Transmission Rebuild Problem
I am rebuilding an 1986 CRX 5 speed stock GW 2 transmission. As I reassembled the main shaft and counter shaft into the casing, the gear mesh on the counter shaft is 2-3 MM lower than the main shaft. Also, the end gear of the counter shaft is “bottoming out” on the bearing retainer plate. This tells me the counter shaft needs 2-3 MM of “lift” to match the gear mesh. However, the Honda shop manual does not show a shim or washer on the end of the counter shaft being needed.
I would appreciate your help.
this is the forum that you want...!!!
https://honda-tech.com/forums/classic-hondas-106/
wasanissanFL
Transmission & Drivetrain
Feb 4, 2016 01:37 PM
Kusai.Nihonjin.Desu
Oct 27, 2003 09:54 PM
