help for window regulator more complicated then it seems???
Old Feb 20, 2010 | 07:23 PM
99d-series's Avatar
Icon6 help for window regulator more complicated then it seems???
i have a 95 honda accord 4 door, and somehow my friend somehow messed up my window and the cable came off the track from wat i can tell.... i though i got it put together but its still not right/perfect it seems to be on the right track but im not 100% of how the cables supposed on the track or where at
i could really use a diagram.....ive looked all over the internet for this and couldnt find anything but how to remove the door panel and change automatic door regulator.
i got the cable to how i think is right and the window now rolls up but doesnt roll down.... and the window **** will keep turnin even though the window is fully up
NEED HELP plz
Old Feb 23, 2010 | 02:46 PM
99d-series's Avatar
Default Re: help for window regulator more complicated then it seems???
UPDATE.......need help please.
i need to know how the wire that helps the window move up and down is laid out/how it runs in the door frame.
Old Feb 23, 2010 | 02:50 PM
19Accord97's Avatar
http://autorepair.about.com/library/a/1i/bl070i.htm
Old Feb 23, 2010 | 07:33 PM
arkangel2487's Avatar
that site doesnt say how to fix the cable but replace the regulator. thats ur best bet and its not hard to do
Old Feb 23, 2010 | 10:57 PM
delta_1980's Avatar
if your only option is to remove the regulator assembly, I suggest you remove it and look for broken parts and try to replace the broken parts with used parts from a junkyard.
I say this because I replaced my wife's window regulator with a Napa part and now the window rocks back and forth in it's tracks. Aftermarket parts are just not made to the same standards as oem parts.
It may seem like a lot of work at first but once you do it, the next time you have to do the same thing it will only take you a third of the time.
Old Mar 11, 2010 | 02:45 PM
19Accord97's Avatar
Ugh, my passenger side window just went out. Now I have to get it replaced before it starts raining. Hope its not to hard
tiffanyaa
May 7, 2017 12:24 PM
Lightsped
Aug 28, 2008 11:14 AM
smooz EK
11
Dec 5, 2006 12:08 PM
Spooled1.6L
Mar 7, 2004 11:18 AM
