Lots of parts and tools for sale
Old Feb 20, 2010 | 05:22 PM
Mike K's Avatar
Default Lots of parts and tools for sale
***PLEASE DO NOT TRY AND PRIVATE MESSAGE ME. I RARELY CHECK THIS BOARD ANYMORE, SO IF YOU ARE INTERESTED IN PARTS PLEASE EMAIL ME: mikek@topshift.com
Ok, now that's out of the way... please buy this stuff. I'm open to reasonable offers on al this stuff. I know pretty much what they are worth, so don't try and offer me $40.00 for an ITR throttle body, ok?
Parts are located in Bellingham, WA. If you're in Seattle or Vancouver BC, I can meet up halfway if needed. Aside from that, I'm willing to ship anything.
The parts are all from a build I was going to do on my 00 Civic Si, but I ended up getting rid of it and now I have an Element... so these parts are al useless to me.
The tools are all things that I don't use anymore. I've been a Honda technician for almost ten years now. The tools were taken care of, and not beat on.
Ok, here goes... once again, any questions? mikek@topshift.com
All parts are used unless otheriwse noted.
B16 HEAD WITH 96 GSR CAMS, IACV AND VTEC SOLENOID
B18A BLOCK, DISASSEMBLED AND READY FOR HONING
CENTERFORCE STAGE 2 CLUTCH WITH GSR FLYWHEEL
ITR PISTONS ON LS RODS WITH ARP ROD BOLTS
CTR PISTONS ON B16 RODS(PISTONS KINDA SCRATCHED UP)
ITR INTAKE MANIFOLD(BRAND NEW)
ITR THROTTLE BODY
ITR WATER PIPE AND COOLER AND HOSES(BRAND NEW)
ITR TRANNY BRACE
BLOX SPEC A CAMS B-SERIES(BRAND NEW)
OBD1 B18B DIZZY MADE TO FIT B16
STARTERS(1 MITSUBA AND 1 CME)
ALTERNATOR BRACKETS
SPEED SENSOR
OBD2 D SERIES DIZZY
B SERIES MAIN BEARINGS UPPER AND LOWER PAIRS(1 PINK, 4 YELLOW)
B18B ROD BEARING PAIRS(1 GREEN, 1 RED, 3 YELLOW)
GSR VALVE COVER(BRAND NEW)
GSR HEAD BOLTS(BRAND NEW)
GSR UPPER AND FRONT TRANNY MOUNTS
GSR REAR MOUNT BRACKET
GSR SHIFT LINKAGE WITH SHIFTER
GSR THERMOSTAT HOUSING WITH THERMOSTAT(BRAND NEW)
GSR HALFSHAFT
GSR REAR LOWER CONTROL ARMS
K24 INJECTOR CLIPS
LS/VTEC OIL LINE WITH FITTINGS
DC SPORTS 2 PIECE STAINLESS GSR HEADER
BEAKS REAR SWAYBAR KITS(1 EG, 1 EK)
ITB VACUUM CANISTER(3"X8.5" WITH 7 FITTINGS)
P28 ECU WITH JUMPER HARNESS
EG WINDOW REGULATOR 72250-SR3-003
BLOX OIL PRESSURE GAUGE(BRAND NEW)
BLOX AIR HORN(BRAND NEW)
M-FACTORY B-SERIES 3.07 1ST GEAR
00 CIVIC SI FOGLIGHT HOUSINGS, HARDWARE AND SWITCH(CRACKED LENSES)
00 CIVIC SI FRONT LIP, MILANO RED(SCRATCHED UP)
00 CIVIC SI AEM COLD AIR INTAKE(RED)
00 CIVIC SI STOCK STRUT BAR
06+ CIVIC SI K&N DROP-IN FILTER
06 HONDA RIDGELINE SERVICE MANUAL
MATCO 1/2" DRIVE 19MM IMPACT WOBBLY CUP19M6B
SNAP-ON NUT DRIVER BLACK HANDLE 8MM NDDM80
SNAP-ON NUT DRIVER BLACK HANDLE 10MM NDDM100
SNAP-ON TEST LIGHT CT4F
SNAP-ON 3/8" DRIVE CHROME U-JOINT FU8A
MAC TOOLS RG1000K HEAVY DUTY RIVET GUN KIT
BLUE POINT OIL FILTER TOOL FWA62121
INGERSOLL RAND 3/8" AIR RATCHET 107XP WITH MAC TOOLS AIR U-JOINT
SUNPRO INDUCTIVE TIMING LIGHT
BENCH MOUNT PISTON RING FILER(NEEDS NEW DISC)
GREY PNUEMATIC 3/8" DRIVE IMPACT SOCKET SETS SHORT AND DEEP(7MM-19MM)
Thanks!!!
Old Feb 24, 2010 | 10:29 PM
uneekvisions's Avatar
Default Re: Lots of parts and tools for sale
you have email on the eg regulator
Old Feb 24, 2010 | 10:33 PM
vtechjunkie's Avatar
A ton of stuff here man. GLWS
Old Feb 24, 2010 | 11:03 PM
sparxx's Avatar
prices might help.
bump
Old Jan 29, 2012 | 09:15 AM
k94cvtec's Avatar
prices would be great bump
Old Jan 29, 2012 | 11:36 AM
DC2_R's Avatar
Tried sending an email but no good.
Looking for prices on the B16A head less GSR cams.
Old Jan 29, 2012 | 07:32 PM
FFerio's Avatar
bump for a legit dude
who-got-rice
Northeast (Sales)
64
Dec 26, 2009 04:54 AM
