timing belt replacement for 05 civic
Old Feb 20, 2010 | 04:24 PM
wambus's Avatar
Default timing belt replacement for 05 civic
We need help ASAP - car apart in driveway....
05 Civic with D17A2 engine. We stupidly took the timing belt off of the engine without setting the cam gear to "up". I moved the cam gear a little while trying to get the belt back on. Then we moved the crank around and back to line up what we thought was the crank timing mark. How do I set everything back up? Is this a zero clearance engine? What do I line up the crank with, or can I even use marks on it? There is an arrow on the block behind the crank sprocket and a line on the sprocket (really the crank position sensor do-hickie). Please help, so this car ca be re-assembled.....
EdwinCheng
May 7, 2014 01:28 PM
wambus
Honda Civic (2001 - 2005)
Feb 22, 2010 08:05 PM
RAK
Jun 2, 2007 03:20 PM
Jonathan_ED3
Apr 12, 2003 02:55 PM
SC94DB8
Aug 23, 2002 04:24 PM
