Transmission compatability 96 DX
Old Feb 20, 2010 | 04:02 PM
bambbrose's Avatar
Default Transmission compatability 96 DX
Hi my wifes 96 DX sedan just had the transmission go out on it.
It's an auto transmission for the 4 cylinder.
I'm wondering what other transmissions are possible to change between this one?
What is the standard procedure for changing an auto transmission? Anyone got a DIY/How to for it?
I don't want to convert to manual (I've done that on a few cars already) as this is my wife's daily.
At the local pick-n-pull there are 5 accords in year range from 94 to 97 with auto transmissions, but the one that is 96 is beat up and high mileage. There is one 94 with low mileage and the engine is in great shape so I'm guessing the trans should be too, but I need to know what years are compatible.
Thanks
Old Feb 20, 2010 | 04:31 PM
02 accord's Avatar
Default Re: Transmission compatability 96 DX
94-97 is what you need.
Old Feb 20, 2010 | 10:36 PM
bambbrose's Avatar
can anyone confirm that there is no difference between the obd1 94-95 auto transmission and the obd2 96-97 transmission?
Old Feb 20, 2010 | 11:14 PM
GhostAccord's Avatar
Both OBD1 and OBD2 VSS sensors, shift control solenoid and lock up control solenoid are the same. The wiring and connectors would have been the only thing I could see being a problem. The mainshaft spline count from 94-97 are the same as well.
Old Feb 22, 2010 | 01:11 AM
MAD_MIKE's Avatar
MM Gruppe B
'94-'97 are the same transmissions.
The only differences are the Wagons have a different FD and possibly larger pan.
Our '95 had a '97 trans in it til recently.
1.5Slowmatic
Engine Management and Tuning
11
Aug 22, 2024 07:49 PM
ceearexx
Oct 22, 2013 10:28 PM
JDMDC2 88
Jan 3, 2012 05:03 PM
The-Kid
Jan 12, 2009 08:44 PM
