Suspension & Brakes Theory, alignment, spring rates....
Brake Upgrade
Old Feb 20, 2010 | 03:49 PM
oldguy's Avatar
Default Brake Upgrade
i am a newbie and i realize this ? has been asked and answered at least a thousand times : what Honda brakes will bolt in , front and rear , to improve my 93 eg that will have a tubo h22 in it ,
thanks
Old Feb 20, 2010 | 11:10 PM
roastbeefrichie's Avatar
Default Re: Brake Upgrade
what knuckles are on your 93 civic eg currently?
Old Feb 21, 2010 | 09:03 AM
oldguy's Avatar
stock i would imagine ?
Old Feb 21, 2010 | 10:58 AM
ok...your 93 eg civic is currently on stock DX knuckles w/ 9.4" front rotors
* good pads, blank rotors, ss lines, fresh brake fluid, a lil grease & tires goes a long way
if you're planning to keep your DX knuckles & upgrading your front brakes w/ oem honda acura parts, there's many options available:
a. DX knuckles > 17cl15vn itr .nsx .legend gs 2-pot . front calipers > machined brackets > 10.3" front rotors
http://www.lukekailburn.com/brakes.html
b. DX knuckles > s2000 . rsx. tsx . front calipers > 11" corrado rotor
http://hondamarketplace.com/showthread.php?t=2569691
c. DX knuckles > fastbrakes adapter bracket > 90-01 integra 17cl14vn front calipers > fastbrakes 11" 4X100 rotor
http://www.Fastbrakes.com/product_p/...%20partial.htm
d. DX knuckles > 03 acura cl front calipers > 11" prelude vtec rotors (re-drilled to 4X100)
http://www.tamparacing.com/forums/ho...-knuckles.html
do you have drum or disc rear brakes?
Old Feb 21, 2010 | 12:24 PM
oldguy's Avatar
drum, what do you suggest ?
Old Feb 21, 2010 | 12:46 PM
a. any complete rear disc trailing arm assembly from 88-00 civic/crx, del sol or 90-01 integra
b. keep your drums trailing arms and bolt parts on
Originally Posted by roastbeefrichie
it's possible to convert from drum to disc (without swapping out your trailing arms) by using a scarebird bracket
http://www.scarebird.com/index.php?id=15
scarebird write-up by CerealWars
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/96-00-civic-scarebird-brake-conversion-write-up-2251647/
scarebird bracket...$85 (plus s/h)
* scroll all the way down to the bottom of the page
when swapping from drum to rear disc, you'll want to consider sourcing a valve proportioner from any rear disc w/o abs
for front brake upgrades, since you have a 93 eg civic, if you upgrade to bigger brakes, it requires more fluid to push the bigger piston. the DX master cylinder won't create enough pressure to accomodate for the bigger set-up. keep your DX booster & upgrade your master cylinder. 90-91 civic EX sedan will bolt on with no modifications, oem honda part # 46100-SH4-A11
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/easiest-brake-master-cylinder-upgrade-yet-1992-1995-civics-364783/
Old Feb 23, 2010 | 10:22 PM
lorenzookc's Avatar
i have a question i have a 94 civic dx if i buy the s2000 . rsx. tsx . front calipers and 11" corrado rotor this is a direct bolt on right (do i need a special bracket)
Old Mar 17, 2010 | 03:07 PM
Justin Olson's Avatar
I would like to know this as well!
Old Apr 26, 2010 | 10:11 PM
jmsplitfyre's Avatar
Question: for a 1996 Civic
If I want to upgrade my front brakes to a 90-93 Integra brake set-up, what exactly do I need?
-Rotors
-Calipers
And what else?
I'm sorry to jack the ops thread, and I apologize if this question has been asked too many times. I tried to search for info but I can't get the exact answer I was looking for.
Thanks in advance!
Old Apr 27, 2010 | 10:50 AM
Trey's Avatar
25 Year Member
-Rotors
-Calipers
And what else?
Thanks in advance!
If you have a CX/ DX then you would also need the front knuckle. IMO, keep your DX knuckle and run the S2000 caliper and 11" rotor.
Old Apr 27, 2010 | 11:45 AM
Thanks for the input, Trey! But as good as your idea sounds, I couldn't do it due to the high price of the s2000 caliper here in our area (Not to mention the rarity of it as well).
I just want something that I can scrap from the wreckers.
When you said I just needed the front knuckle, did you mean the front knuckle of the 90-93 Integra?
Old Apr 27, 2010 | 01:12 PM
Trey's Avatar
25 Year Member
I don't think the 90-93 knuckle is the same as the 94+ teg knuckle. I could be wrong though.
PM BE2 for the S2000 front setup. I got mine from him.
Old Apr 27, 2010 | 03:33 PM
Would it be easier if I just took everything from a 94-00 Integra?
Knuckle, rotor, caliper, mc, bb, control arm?
Old Apr 28, 2010 | 04:45 AM
Trey's Avatar
25 Year Member
Yes. You only need the lower control arm if you plan to use an OEM swaybar.
lorenzookc
Suspension & Brakes
11
Mar 11, 2010 10:47 PM
Powered by VTEC
Mar 7, 2008 09:12 AM
chewymonster
Jun 15, 2007 10:25 AM
Todd00
12
Jun 7, 2002 07:39 AM
