Suspension & Brakes Theory, alignment, spring rates....
sway bars
Old Feb 20, 2010 | 03:24 PM
oldguy's Avatar
Default sway bars
i am a newbie and am building a 93 eg with a h22 turbo , need some help with which way to go for front and rear sway bars , aftermarket or factory ? any help would be appreciated
thanks !
Old Feb 20, 2010 | 05:14 PM
kristo's Avatar
Loved
Default Re: sway bars
Get OEM (JDM) ITR swaybars.
Or Suspension Techniques swaybars.
Both are very good setups.
Old Feb 20, 2010 | 05:23 PM
boostntofu's Avatar
it all depends on what you are trying to do man.
FWD cars tend to understeer more often than not, and having a bigger sway bar in the rear, and a stock size, or smaller size in front will help in handling (reduced understeer) and easier turn of the front wheels while still keeping traction.
I just got my ASR 24mm rear sway bar and rear subframe connector they will be installed next weekend when I have time off from work. I heard its one of the best sway bars you can get from several friends that have EG's in SCCA. However I will determine if it is really that good after it is installed and tested out on the road
Hope that helps you a little bit, I have heard that suspension techniques and oem type R's work well but they are not as big as the 24mm bar that ASR has. I believe oem type r is like 15mm and the st is like 18mm.
Old Feb 21, 2010 | 02:38 AM
kristo's Avatar
Loved
Correct info.
Personally I would first get the ITR (front/rear), which will allready be a huge diff, and then upgrade the rear to something thicker like the ASR 24mm, so you can experience the diff and have a choice.
OEM ITR is 24/22(23 JDM).
ST is 'thinner' bùt made of stronger material ànd it is mounted on the end of the rear LCA's instead of OEM in the middle.
The end mounting reduces required swaybar strength (thickness/material) to obtain same swaybar control force as OEM, while at the same time being more precise due to more swaybar movement for the same wheel movement compared to OEM.
juju000
15
Jun 15, 2010 02:27 PM
kccord
Jul 7, 2009 03:15 PM
envee
Suspension & Brakes
Apr 17, 2007 09:26 PM
H22A4Me
Feb 22, 2006 05:23 PM
marshun
Oct 1, 2005 05:41 PM
