Anyone have a ef8 sir wiring diagram?
My car is blowing hot air all the time. The little dial to turn from hot to cold on the climate control does nothing. It moves but when i turn it and look under the heater box to where the little motor is that moves the linkage it does not move.
I removed the cable from the motor and the cable moves in and out. I check in the engine bay and the little valve there opens and closes. So I removed the heater motor and hooked it directly to battery power and it moved the linkage, so the motor it self is working.
I plugged it back into the under dash harness and turn the heater dial from hot to cold and nothing happens. So i need a diagram of the heater controls for jdm ef8 sir. I problably have a blown fuse or broken wire somewhere. I also removed my a/c and everything that goes with it including the relays. So maybe for the cold air to work properly I need to hook the a/c wire harness and relays back up.
revvin9k
Jan 21, 2005 07:46 PM
