Suspension & Brakes Theory, alignment, spring rates....
obx camber kits
Old Feb 20, 2010 | 11:07 AM
speedfreak44's Avatar
Default obx camber kits
are these good kits, im thinking about them for my eg
any comments
Old Feb 20, 2010 | 12:02 PM
.Manny.'s Avatar
Touching My Member
Default Re: obx camber kits
are you getting these to prevent tire wear?
Old Feb 20, 2010 | 12:07 PM
4cfdeg6's Avatar
I got them on my EM1 last year to help with tire wear. So far so good, haven't had any problems
Old Feb 20, 2010 | 01:01 PM
good, year, just for tire wear, not tracks , daily drive...,
where you bought yours, see some on ebay for 145, front n rear
Old Feb 20, 2010 | 01:19 PM
4cfdeg6's Avatar
Yeah, its my daily driver, the streets are my track. Got mine from eBay but dont remember how much. Make sure to take the car to the alignment shop after having them installed and its tightened, because the idiot who did mines was really tight so it loosened up after a while and had positive camber. Took it back to have it redone and they didnt charge me.
Old Feb 20, 2010 | 01:22 PM
ok nice... will do, i will be present at the alignment shop ....
Old Feb 22, 2010 | 09:34 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You haven't had any tire wear problems because the alignment shop adjusted the front toe to factory specs, not because of any camber kits you had installed or adjusted.
any comments
Most likely those OBX kits are junk. You don't need them anyway for a daily driver. Just take it to an alignment shop, and tell them you only need the toe-in adjusted, which is the only thing adjustable anyway. If they try to tell you they can't unless you get a camber kit, GO TO ANOTHER SHOP because that is a flat-out LIE.
Negative camber can wear tires slightly, but toe-out will eat tires for breakfast!
PatrickGSR94
Suspension & Brakes
835
Jun 16, 2018 04:28 PM
my_gsr_teg
Apr 29, 2010 05:13 PM
91integra_rubio
Apr 23, 2009 07:53 PM
gsr98integra
Nov 8, 2007 08:59 PM
justininhifi
Jun 27, 2003 10:46 PM
