92 accord - abs light?
Old Sep 6, 2002 | 07:02 PM
Leo95SE's Avatar
Default 92 accord - abs light?
so, a family member of mine has a 92 accord ex, and the abs light came on. i havent looked into it, but the dealer said there is a $1000 cost to repair. can anyone point me in a direction to analyze/repair? can you run diagnostic codes, or reset the abs light, similar to the mil?
thanks!
Old Sep 6, 2002 | 07:04 PM
Accord94DX's Avatar
Default Re: 92 accord - abs light? (Leo95SE)
attached to the work order from the dealer there should be a printed quote saying what parts need to be replaced. List those here.
Old Sep 6, 2002 | 08:21 PM
4doorH22's Avatar
Or if you know where the maintenance jumper is jump it and post the ABS code (it flashes error codes just like the check engine light). If they're saying $1K that's a modulator or something but you'd better check that out an ABS light can come on from just a disconnected wheel sensor.
Old Sep 6, 2002 | 08:52 PM
Leo95SE's Avatar
Default Re: 92 accord - abs light? (4doorH22)
cool, thx
just point me in the direction of the jumper for abs, and ill do it.
does anyone know?
im not buying a helms for someone elses car,, i own too many of my own.. lol
Old Sep 7, 2002 | 09:23 AM
4doorH22's Avatar
Darn I can't find a picture of it. It's in the passenger foot well, on the underside of the dash to the right of the glove compartment. Stick a bent paperclip or whatever in there, put in the key, turn but don't start (oh I guess you know that part)... post the code/sub code(s) and I'll tell you what the Helms says.
Edit: It's the exact same jumper you'd use for CEL codes too. Blue one.
[Modified by 4doorH22, 1:24 PM 9/7/2002]
Old Sep 8, 2002 | 08:17 AM
Leo95SE's Avatar
isnt that the ecu?
i thought the abs computer was a separate system.. ill have to look around for it..
thx again!
Old Sep 8, 2002 | 08:54 AM
4doorH22's Avatar
The ABS controller is seperate from the engine ECU, but they use the same jumper to make the code flash.
00n0908
Sep 11, 2016 09:39 AM
more3688
Apr 1, 2010 12:24 PM
kit50si
Jan 5, 2008 06:22 AM
kit50si
Nov 21, 2007 01:24 PM
sneakerfern
Feb 20, 2007 04:37 PM
