Transmission & Drivetrain Gearboxes, Differentials, Clutches
final drive VS close gear ratio
Old Feb 20, 2010 | 05:24 AM
egycasper16's Avatar
Default final drive VS close gear ratio
final drive 4.785
or
close gear ratio
setup is
b20vtec fully build with skunk2 pro
Old Feb 20, 2010 | 05:33 PM
Aquafina's Avatar
Default Re: final drive VS close gear ratio
Rev limit, tire size, whp/wtq, use of car, top speed needed in 4th or 5th?
Old Feb 21, 2010 | 07:12 AM
rev to 8800
210whp
205/40/r17
i don't care about top speed but is it need close gear ratio or final gear 4.785 on a y21 tranny
Old Feb 22, 2010 | 04:27 PM
Aquafina's Avatar
There is a big difference between the two setups. What exactly are you doing with the car?
Old Feb 23, 2010 | 12:09 PM
drag racing and daily driving
Old Feb 23, 2010 | 10:10 PM
Aquafina's Avatar
What is the race weight?
Old Feb 25, 2010 | 06:21 AM
the car weight 1100 kg
Old Feb 27, 2010 | 05:28 AM
any help
Old Feb 28, 2010 | 02:04 AM
Aquafina's Avatar
Close gear set would work the best IMO. FD might shorten up 1/2 too much depending on the tires you're using. Which ratios depend on whether you can rev it out in 4th or are limited to 8,800.
PRLSV
May 3, 2012 09:43 PM
RS_91
Aug 27, 2003 07:31 AM
Dorikamu
Jun 20, 2002 11:39 AM
R2D2
Jun 17, 2002 07:40 AM
