steering wheel????
Old Feb 19, 2010 | 03:41 PM
SoFresh1189's Avatar
Default steering wheel????
hi ive got a 97 civic coupe and i bought an aftermarket steering wheel. jw, how do you get the stock airbag off??
Old Feb 19, 2010 | 03:46 PM
sfar785's Avatar
Default Re: steering wheel????
here
http://www.rbgrn.net/content/23-how-...steering-wheel
Old Feb 19, 2010 | 04:19 PM
mwaedow's Avatar
Those Torx screws on both sides are a pain to get out. They're not the tamper-resistant type, but they're really tight. I tried to remove my airbag, and even with the proper size, I think it was a T-25, I stripped them out. I had to use my Dremel with a little cutting wheel and cut a notch across the head of it, and used a flat-head screwdriver to turn them out. After that it was easy.
Old Feb 19, 2010 | 04:29 PM
sfar785's Avatar
the torx bolts are red loctited in, get a mini torch if you NEED to and heat them up
Old Feb 19, 2010 | 05:32 PM
the torx bolts were easy, btw thanks sfar that was very helpful. one prob i ran into tho, my new steering wheel is aftermarket and i couldnt get the hub on with that reel thing in the way, so i took that off and i removed all the sensors n such and i cut 2 of the wires because there was no way i could remove them. found out that was a bad idea. and now the turn signal relay in the fuse box clicks. any idea how to fix what i did?
Old Feb 19, 2010 | 05:46 PM
sfar785's Avatar
which wire? Never just cut a wire unless you're 100% positive you can do without it.
wow nevermind. my battery is dead and my 4-way swotch was on my bad. all is well thanks a lot
switch... not swotch lol
Old Feb 19, 2010 | 05:47 PM
sfar785's Avatar
good, just don't cut wires in the future lol
Old Feb 19, 2010 | 05:53 PM
i dont usually but im positive it was part of the srs system and the new steering wheel has no airbag so i dont need it. all the more power to the seat belt. lol
Old Feb 19, 2010 | 05:57 PM
mwaedow's Avatar
Air bags scare the bejeesus out of me. I had one go off in my face one time and I did not like it. My '67 Camaro has a metal dashboard and no seat belts. Now that's a car! I think if I were to wreck it, I would wanna die anyway, so it would work out for the best.
Old Feb 19, 2010 | 06:32 PM
well then... lol hey does anyone kno for sure, i wanna presume that taking out the srs fuse means the passenger airbag wont work either, correct?
Old Feb 19, 2010 | 07:58 PM
bsmith100's Avatar
You say this now. Wait until you are actually in an accident and you will be singing a different tune.
Old Feb 19, 2010 | 08:02 PM
Gunmetal_B20_Hatch's Avatar
correct size is T30. I just swapped out my steering wheels less than an hour ago.
Old Feb 19, 2010 | 08:05 PM
sbpphoenix's Avatar
great idea. using flame near an explosive.
Old Feb 19, 2010 | 08:11 PM
Honda-Tech FTW
Old Feb 19, 2010 | 08:19 PM
im just gonna go ahead and guess that means yes.
Old Feb 19, 2010 | 10:50 PM
sfar785's Avatar
hm, guess i didn't think that one through enough....good catch
thebluecrx
Dec 26, 2010 02:44 PM
b18_crx
Jun 19, 2006 09:19 AM
hanskies
May 24, 2006 03:34 PM
Jdmdc4ls
Apr 24, 2006 12:15 PM
Turbo Powa
Jun 24, 2004 02:16 PM
