Where is the coolent upper drain plug located?
Old Feb 19, 2010 | 08:22 AM
nhldogg's Avatar
Default Where is the coolent upper drain plug located?
Where is the coolent upper engine block drain plug on a 1998 Accord v6 sedan? I have air mixed in with my coolent and what i need to do is run the car and losen that bolt to let the air out and then tighten it back up. If you could tell me where it is located or post a diagram that would be great! Thanks!
Old Feb 19, 2010 | 09:25 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Default Re: Where is the coolent upper drain plug located?
http://www.hondaautomotiveparts.com
try this website and search for a diagram.
I've drain my coolant and seldom drain the block, there should be a bleed bolt to burp the system (usually located on the T-stat housing), unless your V6 is different from the Inline 4 accords.
Old Feb 19, 2010 | 11:29 AM
team-DI's Avatar
u can purge air from coolant system by removing the radiator cap and letting the car run til the fans turn on..
Old Feb 19, 2010 | 01:10 PM
tamadrummer1120's Avatar
there you go.
Per AllData
Old Feb 19, 2010 | 02:15 PM
nhldogg's Avatar
Thanks for the help but wont the coolent spill out if the cap is off while the car is running?
Old Feb 19, 2010 | 02:24 PM
redbull-1's Avatar
No. Practically, this is done every time someone change the coolant and purges the system of air.
HankYee
Mar 12, 2023 12:15 PM
Jeff Lebowski
Nov 14, 2016 05:02 PM
integra_101
Mar 17, 2010 04:02 AM
TypeRuz
Dec 5, 2003 09:15 PM
drumsy
Sep 12, 2002 06:46 AM
