Ground Control Coilovers
Old Sep 6, 2002 | 05:41 PM
TypeR1558's Avatar
New User
Default Ground Control Coilovers
How do these perform? Just something for looks?
Jon
Old Sep 6, 2002 | 06:28 PM
Big Phat R's Avatar
Default Re: Ground Control Coilovers (TypeR1558)
Ground control does not sell coilovers. They sell coilover sleeve kit that turn your suspension setup into a height-adjustable one. (OEM suspension is technically a coilover (shock) setup - it just isn't height adjustable).
You choose the shock (e.g. Bilstein, Koni, GAB) and they supply the sleeve kit and Eibach ERS race springs. You get to choose the spring rates.
How a suspension performs depends on the setup, alignment, damper settings etc.
Old Sep 6, 2002 | 06:37 PM
TypeR1558's Avatar
New User
Default Re: Ground Control Coilovers (Big Phat R)
So, will lowering the car 1.5 with Ground Control and the springs they provide make the stock shocks I would use wear just as fast as they would if I just went with some springs like H&R Sports to drop the R 1.5 inches. Are the eibachs that come with the Ground control kit designed to work with the stock shocks like the H&R sports are?
From the way you describe it, I could upgrade to aftermarket shocks with either the Groundcontrol kit or the H&R Sports later. Any thoughts, because I need to buy within the next week.
Jon
Old Sep 6, 2002 | 07:24 PM
ZygSpeed's Avatar
I'd just go with the H & R springs on the stock shocks.
I liked the ones I had, and Mike K likes them now.
P.S. I'm not sure if the H & R sports actually drop an R 1.5 inches, more like 3/4" lower than stock "R" ride height. Ed
[Modified by Zygspeed, 11:26 PM 9/6/2002]
Old Sep 6, 2002 | 07:33 PM
norice's Avatar
FYI, They do sell Advance Design coilovers. $400 per shock.
Old Sep 6, 2002 | 07:42 PM
Big Phat R's Avatar
Unless you use a spring rate similar to OEM (~240 lb/in) - I wouldn't recommend using the stock shocks - you will just burn them out. The H&R sport springs are probably around 300 lb/in at most. The Eibachs are meant to be used with aftermarket shocks that (ideally) have been revalved to work with the chosen spring rates.
p.s. I forgot about the Advance coilovers (not ever heard of any one buying these) - my bad
Old Sep 6, 2002 | 08:34 PM
DaRKniGhT ITR's Avatar
I have the ground controls by eibach on my R..and i must say i loved the ride..i dropped my R a lil lower than normal though..like almost 2 inch. in the back and a lil more than 2 in the front...it looks ..tiiiiiight.....only problem is..i blew my shocks..doh! Koni yellow adjustables here i come....great ride though... ground controls kick..
CivicSi95
Suspension & Brakes
Jun 29, 2009 11:12 PM
Riceball
Suspension & Brakes
Jul 7, 2006 09:14 PM
rasta420
14
Dec 4, 2002 04:09 AM
TypeR1558
Nov 21, 2002 03:30 PM
paulyman
Jun 10, 2002 05:16 PM
