** KSPORT COILOVERS ** BEST PRICE ON THE NET & FREE SHIPPING **
CLICK HERE TO GET TO OUR SITE TO ORDER
(BE SURE TO USE PROMO CODE MODIFIED)
Kontrol Pro Coilovers
Product Description
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
FEATURES
- 36-way adjustable dampening
- Made from high quality 6061 Aluminum with T6 for increased hardness
- Compression/Rebound adjustable
- Adjustable spring perch for height adjustment
- Adjustable body allowing maximum suspension travel
- Pillow Ball Top Mount w/ adjustable camber (not available for some models)
- Monotube High Pressure Design reduces oil leakage
- Electroplated body for protection from corrosion and rust
- One Year Limited Warranty
GT Pro Coilovers
Product Description
Ksport GT Pro Damper System provides the ultimate in suspension technology featuring its inverted monotube design, 36-way adjustable dampening, adjustable spring perch, adjustable body and pillow-ball mounts. With the gas/oil chamber farther away from the knuckle and braking system reducing heat transfer This design also reduces under-sprung weight, which improves handling and responsiveness.
FEATURES
- Inverted steel shock absorber for durability
- Lower center of gravity and higher chassis rigidity
- Designed to reduce friction for cooler shock oil temperature
- Inverted design like vehicles in WRC and all JGTC cars
01-05 Civic Click For More Info & To Order
02-05 Civic Si Click For More Info & To Order
06+ Civic Click For More Info & To Order
KSport GT Lowering Springs
Product Description
Ksport GT Lowering Springs have been designed to give your car superior handling with an aggressive race look. Most other brands use a linear rate, but Ksport utilizes a progressive rate for several reasons. A progressive rate allows a plush comfortable ride under normal travel, but since the rate shifts higher during compression, it stops “body roll” during heavy braking, hard acceleration, or fast cornering. By lowering the center of gravity from OE height you dramatically improve performance and handling characteristics.
FEATURES
- Progressive rate design
- High tensile chrome silicone wire
- Cold wound for strength
- Shot peened for increased stress relief
- Aggressive drop while retaining superb handling characteristics
