Hybrid Experts.. Please review my parts list for B16 into 91 crx
Old Sep 6, 2002 | 05:02 PM
Monty's Avatar
Default Hybrid Experts.. Please review my parts list for B16 into 91 crx
Please review my parts list. I checked and double checked the rear main seal but have not installed it yet. Do you agree its the same??
I think this would be good to archive. I wish I would of had this list 6 months ago..
I went with everything
Water Pump 19200-P30-003 94 - del sol $86.28
Head Gasket 12251-P30-014 94 - del sol $57.56
Oil Control Orfice O ring 15142-PH3-003 94 - del sol $1.36
Intake Manifold Gasket 17105-P30-004 94 - del sol $8.26
Exhaust Manifold Gasket 18115-P30-013 94 - del sol $11.30
throttle Body Gasket 16176-PR3-010 90-91 integra $4.71
Pcv valve 17130-PM6-G01 94 - del sol $11.98
Timing Belt 14400-PR3-004 94 - del sol $48.72
Alternator Belt 31110-PR3-003 94 - del sol $7.56
Tensioner 14510-P30-003 94 - del sol $50.94
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same) $11.69
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same) $2.76
Cap & Rotor Assembly 06303-PR4-000 90-91 integra $24.54
Rotor (If needed seperately) 30103-PR3-016 90-91 integra $6.87
Clutch Cable 22910-SK7-A02 90-91 integra $45.54
Throttle Cable 17910-SK7-A03 90-91 integra $17.18
Cam Seals (2) 91213-PR3-004 94 - del sol $8.52
Oil pan seal 11251-P30-004 94 - del sol $18.64
Oil Filter 15400-POH-305 94 - del sol $4.93
Shift linkage bushing 54303-SB2-010 90-91 integra $4.66
crank seal 91212-PR3-003 94 - del sol $5.78
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same) $12.00
Valve cover grommets (8) 90442-P30-000 94 - del sol $20.80
Spark Plug O rings (4) 12342-P66-000 94 - del sol $7.16
Rubber plug for exhaust cam tranny side 94 - del sol $4.00
Spark Plugs (4) BKR6E-N11 NGK $8.00
Upper Radiator Hose 19501-PR3-000 92 - integra gsr $14.71
Lower Radiator Hose 19502-PR4-A00 90-91 integra FREE BY MISTAKE
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol $5.62
Washer for coolant drain on block 90401-PR4-000 94 - del sol $3.00
Thanks in advance for checking it over,
Monty
http://www.norcalcrx.org
1991 CRX SI
mileage = 123456
time to install the bee one six!~
[Modified by Monty, 2:03 AM 9/7/2002]
Old Sep 6, 2002 | 05:42 PM
Jared's Avatar
Default Re: Hybrid Experts.. Please review my parts list for B16 into 91 crx (Monty)
looks perfect man. are you doing a rebuild or just putting in all new seals/gaskets before installing?
Old Sep 6, 2002 | 06:09 PM
Civicboy's Avatar
Wow thats a detailed list. I may have to use that
Old Sep 6, 2002 | 07:11 PM
tSuperbike69's Avatar
Default Re: Hybrid Experts.. Please review my parts list for B16 into 91 crx (Civicboy)
I think you need a 92-93 int dist. cap I think they are different but dont quote me???????
Old Sep 6, 2002 | 08:11 PM
FUP23's Avatar
New User
Default Re: Hybrid Experts.. Please review my parts list for B16 into 91 crx (tSuperbike69)
Its 90-91 Integ Cap and rotor
Old Sep 7, 2002 | 05:41 AM
Monty's Avatar
Default Re: Hybrid Experts.. Please review my parts list for B16 into 91 crx (Jared)
I rebuilt the head to Stock 94 del sol. I wish I could of went Type r valve train. Pistons looked good, so I didnt do any bottom end work. If its bad I will probably go with type r block, or rebuild and stroke this block.
Thanks for the help.
Monty
WindyIce
17
Nov 16, 2015 05:42 AM
flaxx0r
Feb 28, 2009 06:18 PM
Origin
Nov 3, 2003 07:56 AM
91hatchnewb
Apr 28, 2003 01:54 PM
bluecrxsi
22
Feb 25, 2003 04:47 PM
