b18c1 bottom end build
alright today my b18c1 started a rod knock. Great right? I need idea on a good build idea i kinda wanna just go OEM parts on it but i kinda just want to know what parts i need and price and lists. Ha i really dont know what to replace as this is my first b18c1. And places i can go to get the parts. IM kinda on a buget because i just bought the car. Just leave comments and suggestions on what rods bearings and pistons are good to use and prices.
this is the site im using for my turbo rebuild.... http://www.importperformanceparts.net/
If all you had was a small rod knock, then just buy the bearings, a gasket set, some new rings, and call it good. Take the block into a machine shop to have them clean it, hone the cylinders, and check the oil pump out. Take them the head for cleaning, test valves for leakage, and change the valve seals. This process shouldn't take you more than a day from start to finish.
sinatra
12
Oct 16, 2003 06:56 AM
