Strange humming/grinding sound from front driver's side while turning
Old Feb 18, 2010 | 01:59 PM
basmasta7's Avatar
Default Strange humming/grinding sound from front driver's side while turning
Hi everyone,
Here's my situation:
While driving, I hear a humming / slight grinding noise from my front driver's side wheel while turning to the right. The frequency of the noise seems to change once per wheel revolution (indicating that the situation changes as the wheel rotates around). It goes away completely while turning to the left. In other words, when the suspension on that side is loaded, I hear the sound. Also, I don't know if this is related, but the rotor in that corner warps continuously. I swap out new brembos every year or so, and it always comes back. I always use a torque wrench on my lug nuts so that's not the problem either.
My troubleshooting:
I've done quite a bit of searching, and everyone seems to suggest that something like this is a wheel bearing, CV joint/boot, or axle. I had a mechanic replace the wheel bearing and inspect the other items and the noise is still there.
What do you all think?
Old Feb 18, 2010 | 03:32 PM
basmasta7's Avatar
Default Re: Strange humming/grinding sound from front driver's side while turning
Update:
After driving on the highway after the mechanic replaced the wheel bearing, there is now a very noticeable metal to metal rubbing sound when I load the front driver's side suspension (either via a bump or a hard turn). It sounds like it's just the dust shield hitting the rotor or something, but regardless - it seems like there's some movement going on that shouldn't be. Why would the dust shield move independently from the rotor (besides the obvious lack of rotation)?
Mr.Chow
Oct 3, 2011 07:54 AM
Sorcin
Suspension & Brakes
May 19, 2010 05:16 PM
jkalex05
Nov 23, 2009 06:52 PM
David12
10
Nov 15, 2009 01:35 PM
sf89lx
Aug 26, 2004 10:05 AM
