1997 honda civic misfire
Old Feb 18, 2010 | 10:26 AM
kadinz's Avatar
Default 1997 honda civic misfire
b16 blah blah... im not big on these engines, or cars actually...(im a domestic guy but i am looking for some help..my dad bought this car not knowing that this misfire is an actual problem, he saw low miles and low price and bought it.) i know its got no cat and an aftermarket tune apparently to pass emissions and the after-cat o2 sensor is deleted.. did the whole tune up thing, whats next..? i brought it to a shop and the guy said its running lean, i asked him how does he know that...he said it was the last code that was pulled which was awhile ago, i doubt its running lean.. and if it is, would that cause a misfire?
Old Feb 18, 2010 | 10:35 AM
noremorseracing's Avatar
Default Re: 1997 honda civic misfire
it needs the o2 sensor to fix the lean issue
Old Feb 18, 2010 | 10:39 AM
kadinz's Avatar
aaaand a tune wouldnt fix that...? idk if it is even running lean, that was just the last code that was pulled awhile ago..
Old Feb 18, 2010 | 02:55 PM
spidermancivic's Avatar
Is this an ex, lx, dx? engine is a?
What is a tune? im assuming your saying he paid someone to pass smog illegally. what is the actual code?
Theres too many reasons why a misfire can occur and running like crap. If your concerned about the car running properly, a start would be to put the original exhaust manifold/catalytic convertor combo on it to resolve the o2 sensor problem. If that in turn does not resolve the misfire problems, you can check the other possible problems like:
clogged exhaust system, low compression, vacuum leaks, etc. do a search, and you will find more places to look.
regardless of your great knowledge of domestic vehicles, if your missing an o2 sensor, whether it be an import or domestic, you will not pass smog. The ecu will be looking for it. and whether you own a domestic or import, the problems to check concerning misfires as listed above, applies to all vehicles.
have a nice day.
Old Feb 18, 2010 | 04:06 PM
96_cvc_b16's Avatar
true^^^
Old Feb 18, 2010 | 05:18 PM
kadinz's Avatar
have a nice day.
did not say i have great knowledge of domestic vehicles, i was just stating thats my only knowledge. thanks though.
Old Feb 18, 2010 | 06:43 PM
Jimster480's Avatar
well what model is the car? what year? what engine? any check engine lights? Is it OBD1 or OBD2? We need more info to help you out. It can be a issue with the spark plugs, wires, ICM, ECU, O2 Sensor, etc.
dtaylor630
Honda Civic (2001 - 2005)
Sep 21, 2015 06:44 AM
civic4681
Honda Civic (2006 - 2015)
Jul 4, 2013 06:25 AM
mommyslittlegreaser
10
Jan 23, 2008 06:29 PM
vinuneuro
Sep 13, 2007 08:44 AM
chomorro
Jun 26, 2006 10:24 AM
