Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
17x8.5 +50mm, Am I going to Rub?? Need Spacers???
Old Feb 18, 2010 | 04:04 AM
ilovejdm's Avatar
Default 17x8.5 +50mm, Am I going to Rub?? Need Spacers???
I ordered a set of wheels not knowing that I might have rubbing issues with this size, they are going on a sedan. Will I have rubbing issues? what spacer am I going to need to run??
Old Feb 18, 2010 | 11:04 AM
csmiths98AV6's Avatar
Default Re: 17x8.5 +50mm, Am I going to Rub?? Need Spacers???
you are going to rub for sure on the inside. my 8.5 +41 had like 3mm of clearance with stock struts. id say a 15mm spacer
Old Feb 18, 2010 | 02:46 PM
ajpturbopittsburgh's Avatar
It depends on what size tires you are going to use. With a 215 or 225 I don't think you will need spacers at all.
I have 19x8 with 55 offset and 245/30/19 with no spacers and steering wheel fully locked over they rubbed the fender liner on the inside by the motor not the outside. And I had to put 20mm spacers to clear my wilwoods and they don't rub anywhere now.
If you compare it to my setup you have this: Your wheel is .5" wider but your offset is 14 milimeters less, which puts you 14mm closer to the outside of the car when compared to me. There is 25.4mm in 1 inch. So 14mm is just about .5" which cancels out the extra width that your wheel is over mine. So if you keep a stock rolling diameter, which mine is very close to, then you should be able to run what I have which is 245 tire width. So that's why I say a 215 or 225 should be safe without spacers.
Still with me? I pondered this for awhile when I got my wheels. It's gets confusing when you start looking at offsets and spacers.
Old Feb 18, 2010 | 03:47 PM
ilovejdm's Avatar
lol gets confusing! I'm just nervous because people keep telling me its going to rub the shock
Old Feb 18, 2010 | 03:51 PM
i-VTEC_DOHC's Avatar
you need a lower offset.
im on 8.5 with +30 and i rub my fenders.
Old Feb 18, 2010 | 03:54 PM
My bad I just saw that you had 50mm offset. It was the other guy that replied that had 41mm. So you will be 9mm closer to the shock. I still think you would be safe with a 215 or 225 but it will be close with out a spacer. Avoid spacers if you can. They put more stress on your studs and wheel bearings. Buy high quality hub centric spacers such as H&R and do it right if you do
I doesn't matter how close you are to the shock as long as it's not touching. The shock and tire move in unison as you turn the wheel because the shock is bolted the the knuckle.
Old Feb 18, 2010 | 04:36 PM
asianskater91's Avatar
^^^good info right there ajpturbopittsburgh (even though ajp sucks) lmfaojkjk
but hey "i love jdm" im the kid that was picking on you in the other thread lol
Old Feb 18, 2010 | 04:44 PM
If he puts on 20mm spacers, his and yours would effectively the same.
8.5" 50 offset with 20mm spacers = 8.5" 30 offset.
Ivtec do you run 225's?
Old Feb 18, 2010 | 05:17 PM
yea thats true, but i dont think the op wants any problems rubbing. i think a 35 offset on an 8.5 wouldnt rub depending on your tire size.
and to answer your question, yes. im running 225/40 17. not a size you see everyday.
Old Feb 26, 2010 | 08:05 PM
ilovejdm's Avatar
E-thugging at its finest!!! never had someone chase me from one honda site to another!! lmfao
Old Feb 26, 2010 | 11:57 PM
mrxlazy's Avatar
on 235/40 tires, all you need is a 5mm spacer. 8.5 +45 offset should clear everything. +50 offset rubs the strut on the passenger front side and it rubs the gas tank rear left side if im not mistaken.
Old Feb 27, 2010 | 06:56 AM
suwhoop's Avatar
+50 offset?? lol damn shoulda got +20
Old Feb 27, 2010 | 11:40 AM
thats correct sir.
on my current setup, i have about 1mm of clearance with my front shocks because i run full negative camber in the front to avoid rubbing. the rears are also full negative camber, but i never checked the clearance, but im sure im nowhere near rubbing anything.
this must be his first set of wheels he bought because thats an error most people do. they buy wheels because of the size and lug pattern and they dont know about offset and sometimes the wheels dont fit or the offset is real high and they dont like how far in the wheels sit.
Old Feb 27, 2010 | 12:14 PM
Hey Ivtec when you say you run full neg. camber does that mean the tops of your tires are tilted in towards the motor? Does that play hell on your tire wear?
Old Feb 27, 2010 | 04:43 PM
full negative is only 1.75 degrees. yes the tops are towards my motor, i obviously cant run positive because i would've had a blow out by now from my fender slicing my $700 tires. and 1.75 is basically what you get when you lower it on sportlines because thats how much my camber was when i had them.
Old Feb 27, 2010 | 04:54 PM
how are you going to give people offset advice when you dont even know which way the tire is tilted with negative camber. LMAO
Old Feb 27, 2010 | 08:49 PM
^that's low dude hahaha but i gotta hand it to you, he set it up and you capitalized on it.
Old Feb 27, 2010 | 09:50 PM
I figured you would go there but just becuase I don't know about caster and camber settings doesn't mean I don't know about a tire and wheel package fitting based on tire and wheel width and offsets.
All I know is that what I have doesn't leave room for a wider tire or wheel. So based on wheel width and offset when compared to mine I feel I have pretty good handle on what will rub or not
Old Feb 28, 2010 | 08:37 AM
i think you have an idea of what won't rub on 19's.
where are the pics of your car?
Old Feb 28, 2010 | 04:47 PM
Old Feb 28, 2010 | 05:06 PM
Greg50Lt's Avatar
wheels look good. tad to big for my taste. Your tires have no stretch to them. You could run the next size down and lower the car more without messing with camber.
Old Feb 28, 2010 | 05:31 PM
why 19's?
just curious.
are you getting the jdm fever?
Old Feb 28, 2010 | 05:35 PM
Well I just have HFP springs so I'm non adjustable. But when you change the camber won't that make the inner part of the tires wear quicker? I paid enough for the tires so I just want them to wear evenly.
Old Feb 28, 2010 | 05:36 PM
arent the s drives near the bottom on the yoko list?
Old Feb 28, 2010 | 05:41 PM
why 19's?
just curious.
Haha no jdm fever.
I actually would've picked 18's for a bit more tire sidewall height but I found this style wheel and really liked them and I was hell bent on stuffing 245's in there so I had to get the 30 series tire to maintain stock diameter. I didn't have a fortune to spend on wheels so these were like 1200 with new tpms sensors and I figured HFP are better quality than cheapo wheels and they are only slightly heavier than my stockers.
