swap trouble, fuel pump doesnt prime
so i swapped another b series into a 98 hatch and the motor cranks ecus work, cant fine a blown fuse. the ecu is not giving me any codes and the fuel pump does not prime, any ideas?
The main relay would be another thing to check. I can't say whether or not that would stop you from cranking it over though. I had a full array of problems when i swapped my built engine in so i can feel for you on this one. Good luck
civic2liters
Jun 1, 2008 08:11 PM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
