H&R springs w/aftermarket camber kit?
For all of those that currently have or had H&R lowing springs. Was the factory camber enough to re-adjust back to "normal specs" or did you have to purchase an aftermarket camber kit, such as Buddy Club to get the camber correct?
Depends upon how much the lowering springs lower the car. And you'll only need camber correction in the rear, unless you absolutely must have OEM camber settings.
And camber is not factory adjustable.
allmotorEG-SI
Jun 12, 2003 12:00 PM
