WTB 92-95 civic lower radiator support
What do you mean lower support? It comes in one piece. I have a lower section cut out if you can make it work...No damage..never been wrecked car.
pm me and let me know exactly the piece you are in need of.
Yes, the civic front radiator (core) support is a 1 whole piece assy and you would have to drill out the spot weld to replace it. personally i recomend getting a used OEM radiator support because the aftermarket one are weak in quality. i have had use an aftermarket one prior and jacked up the car and the bottom of the support bent.
But i do have a whole OEM non-drill out front radiator support if you' want that. i had cut it off a rear-ended civic from the shock tower. let me know.
thanks
thanks
dturbo
Mar 5, 2008 05:43 PM
