why do i keep burning valves up?
Old Feb 17, 2010 | 12:37 PM
2wheelhunter's Avatar
Default why do i keep burning valves up?
I have a nearly stock '00 GSR it has an intake/header/exhaust. For some reason i keep toasting my valves, this is the second time now, and it keeps happening on cylinder 2. i replaced the injectors several times. i think that it is just running lean. both times a chunk has been taken out of the flat part of the valve. i will post pics later! any help?
Old Feb 17, 2010 | 09:56 PM
jakobe06's Avatar
Default Re: why do i keep burning valves up?
I had the same problem and it was because a couple of my valve guides were cracked. I would check that and see if thats the problem especially if its on the same side of the valve as last time
Lsvtecy0
May 15, 2016 11:16 AM
Topdawgg
Jan 7, 2010 06:46 PM
white_n_slow
May 15, 2005 07:51 PM
sneakychaos
Sep 9, 2002 05:48 PM
