Wideband Questions
Old Feb 17, 2010 | 08:04 AM
94DCTeg's Avatar
Default Wideband Questions
Hello Members, I have a question to ask
I have a 92 Civic with a D16z6 swap with a P28 ECU, the car had an AEM UGEO wideband in the car when I bought it , the previous owner was planning on doing a boosted setup, I was wondering what the wideband should be running at, it seems like the car is running rich, just crusing with about 1/2 throttle the gauge reads any where from 11.9 to 12.2, nothing higher and at an idle the gauge reads about 11.1 to 11.4, which seems to me like its running really rich, as far as I know the motor is completly stock, from what I understand the gauge should read about 14's at 1/2 throttle or am I incorrect ?? It has been really cold here in good ol North Dakota, I'm sure the cold weather has an effect on how rich or lean the car should be running, is it safe to run the car at these number
Thanks for all the assistance I appreciate it
Thomas
Old Feb 17, 2010 | 08:56 AM
shogee's Avatar
Default Re: Wideband Questions
yes that is really rich, idle should be about 14.7, part throttle around 13-14
Old Feb 17, 2010 | 09:02 AM
97twodoor's Avatar
I second that. Is the computer chipped at all? Just wondering if it's running a different map. Any codes?
Old Feb 17, 2010 | 09:08 AM
94DCTeg's Avatar
as far as I know the ecu is not chipped, its not throwing any codes at all either.
Old Feb 17, 2010 | 09:16 AM
97twodoor's Avatar
I would start checking sensors then, like O2 sensor, MAP, TPS. Pull a plug out, and see if it's black just to confirm what the A/F gauge is telling you. Maybe the wideband O2 sensor is not working correctly.
Old Feb 17, 2010 | 09:19 AM
94DCTeg's Avatar
just got ahold of the previous owner, and he said the ecu is chipped
Old Feb 17, 2010 | 10:41 AM
97twodoor's Avatar
Well looks like you found you're problem then. Get a stock map then burn it onto the chip and you're in business.
Old Feb 17, 2010 | 10:44 AM
Relic1's Avatar
^^^ beat me to it.
chip = why it's running rich.
remove J1 (just above the chip) and you'll be back to the stock program again.
that is IF you're still running the stock injectors.
Old Feb 17, 2010 | 10:45 AM
D16SiHatch's Avatar
or you can cut jumper j1 and the ecu will revert back to the stock map. some people have even soldered a cheap switch to it so that they can switch back and forth between the chip and the stock map when they want to.
edit: ^dayum, beat me to it lol
Old Feb 18, 2010 | 07:47 AM
94DCTeg's Avatar
Originally Posted by Relic1
^^^ beat me to it.
The chip that was in the ECU said Vtec 4800, redline 9000, and manufacture sticker said Skunk2 Racing, so it seems to be some cheap ebay chip that had bad fuel tables, a good friend of mine got her all tuned up with the correct fuel, thanks for all the answers and help I greatly appreciate it
Old Feb 18, 2010 | 08:49 AM
97twodoor's Avatar
Good stuff man, glad you got it all worked out.
Old Feb 18, 2010 | 10:59 AM
94DCTeg's Avatar
Thank you and I am glad she is all figured out, it was no fun getting 150 miles out of a full tank of gas haha
Old Feb 18, 2010 | 11:13 AM
97twodoor's Avatar
Haha yeah i bet.
Old Feb 18, 2010 | 12:56 PM
Matt93eg's Avatar
150 miles to a tank would SUCK! Glad you got it figured out. So does it run better now? Just curious.
Old Feb 18, 2010 | 02:20 PM
BigSorn's Avatar
WOO Someone else from ND.
Old Feb 19, 2010 | 06:28 AM
94DCTeg's Avatar
oh hell yes the car runs 100x better haha !!
Old Mar 4, 2010 | 01:07 PM
jdm701's Avatar
i gotta take you up on that ride sometime thomas...glad to hear she's running great....yup the plans were to boost her ...o0h do i miss her .....but im glad it went to good hands!
Jeremiah Velez
Engine Management and Tuning
Nov 3, 2017 04:46 PM
lsvtec92teg
Jan 5, 2005 11:52 PM
CWBETB
May 12, 2003 04:30 AM
97hb
Mar 21, 2002 09:19 PM
97hb
Mar 21, 2002 07:02 PM
