What is wrong with these???
Old Feb 17, 2010 | 05:00 AM
Teamdiesel's Avatar
Default What is wrong with these???
A friend of mine bought an ITR head with ITR valves with all the exhaust valves looking pretty wack. All the intake valves look good with no build up but the exhaust valves had a hard substance which would not come off even after been soaked in a heavy degreaser for four days. Could someone tell me what happened to cause them to look like this and can they be cleaned and reused?
Old Feb 17, 2010 | 05:43 AM
88Hatchy's Avatar
Default Re: What is wrong with these???
Simple green + drill press + steel wool = clean valves
Old Feb 17, 2010 | 05:51 AM
Teamdiesel's Avatar
simple green + drill press?? what do you mean?
Old Feb 17, 2010 | 06:27 AM
negusjuda's Avatar
he means clean them lol
Old Feb 17, 2010 | 06:39 AM
97twodoor's Avatar
Just wire wheel them.
Old Feb 17, 2010 | 09:02 AM
95skunkedgsr's Avatar
if you have a drill press lock the valve top into a drill press turn the press or hand drill if your feelin froggy on and press the bottome of the valve (dish part) into the steel wool , make sure the valve are wet with the simple green , purple power or what ever you use , keep a eye on it while you do it so u dont make it out of round or anything
Old Feb 17, 2010 | 10:44 AM
welfarepc's Avatar
that happens when you have a motor that burns oil.
Old Feb 17, 2010 | 11:06 AM
Teamdiesel's Avatar
well I carried the valves by a friend of mine to get them cleaned up. He said he did the best he could without taking off to much of the black coating the valves came with. Tell me what you guys think, and if the valve will now need to be grounded to reseat them?
Old Feb 17, 2010 | 02:04 PM
1.5Slowmatic's Avatar
soak them in some carb dip. be clean as new
Old Feb 17, 2010 | 02:19 PM
Teamdiesel's Avatar
You mean Carb cleaner right?
Old Feb 17, 2010 | 02:25 PM
Natural Aspirations's Avatar
I have done the drill press meyhod before and had great results.
Fuel deposits and oil are probably the root cause of the scal3.
If you tape off the stems with electrical tape you could get away with bead blasting them.
I wouldn't worry much about the coating on the valve.
Old Feb 17, 2010 | 02:27 PM
Carb dip is different, i haven't had the best sucess with it cleaning up burnt on deposits
Old Feb 17, 2010 | 06:37 PM
no
this stuff is kick ***. it takes anything and everything off
http://ecx.images-amazon.com/images/...500_AA260_.jpg
berrymans carb dip is what is called. watch your skin though, its rough
boosted k20
Feb 15, 2016 05:11 PM
ferio-ichi3
Sep 19, 2013 08:31 PM
rotascircuit
Dec 23, 2009 05:37 PM
njracer
Nov 2, 2007 02:36 PM
Crossett
Nov 15, 2001 02:19 PM
