electronic load detector!any ideas?
Old Sep 6, 2002 | 02:26 PM
4gvtec's Avatar
Default electronic load detector!any ideas?
it keeps showing up and i have to reset the ecu.anyone had this problem?if so can you help out?
Old Sep 6, 2002 | 02:52 PM
FUP23's Avatar
New User
Default Re: electronic load detector!any ideas? (4gvtec)
You running the stock ecu ?? You may have to replace your eld in the underhood fuse box
Old Sep 6, 2002 | 03:00 PM
ImportHatch's Avatar
Default Re: electronic load detector!any ideas? (Devin17)
I have the same code in my crx. Its a 88 si with a z6 runnin the p28 ecu.
Yager-
Old Sep 6, 2002 | 03:06 PM
FUP23's Avatar
New User
Default Re: electronic load detector!any ideas? (ImportHatch)
Its prob your ecu man ... I ran my B18A1 on my Crx Si ecu for a day and it threw the code 20 ..i got my pr4 and went away
Old Sep 6, 2002 | 04:56 PM
Jared's Avatar
depends on whether the ecu looks for an eld or not, and whether or not the car was wired with one to begin with.
Old Sep 6, 2002 | 06:24 PM
4gvtec's Avatar
Default Re: electronic load detector!any ideas? (Jared)
heres the deal.i pulled out the ecu when i had the car running and it stumbled on the idle and allmost died.i tracked it down to the c plug.if i wiggle it it idles shitty and allmost dies.i check the wires and there fine.i think its the pins on the ecu socket or board.i found a guy tonight who has a 90 si crx or pm6 ecu that i will try.
my ecu is a pm6.
whats an eld?
[Modified by 4gvtec, 3:25 AM 9/7/2002]
Old Sep 14, 2002 | 06:21 PM
eld = electronic load detector
Yager-
Old Sep 14, 2002 | 09:25 PM
oldskool_rex's Avatar
what that guy said.
Old Sep 14, 2002 | 10:30 PM
Overkll's Avatar
You may not have an ELD in your fuse box, and the new computer doesn't know that. It doesn't effect your engine with this code. I've run it in a ZC for over a year and a half. No performance losses. Doesn't go into limp mode at all. RUN it with the code, or get an ELD for your fuse box. Later, Overkll
Old Sep 14, 2002 | 10:37 PM
Default Re: electronic load detector!any ideas? (Overkll)
the 88-91 civics do have an ELD (at least the Si does)
Old Sep 15, 2002 | 04:30 AM
jc836's Avatar
The ELD is part of the fuse box and is standard in the 89-91 CRX Si.
Old Sep 15, 2002 | 09:41 AM
Default Re: electronic load detector!any ideas? (jc836)
Basically an ELD turns on and off the alternator so it is not charging when it does not need to. It detects engine load and the ecu decides how much juice the car needs before it lets the car draw current from the alternator. I drove around with a faulty one for over a year. It doesn't hurt anything.
Old Sep 15, 2002 | 10:47 AM
4gvtec's Avatar
Default Re: electronic load detector!any ideas? (oldskool_rex)
makes sense,the bat light some times is lit during the day real dim.
suzawa94
Dec 29, 2005 09:37 PM
i20ar
Jul 19, 2004 07:42 AM
Fatty_1775
Aug 5, 2003 05:37 AM
00fbp
Aug 16, 2001 08:18 PM
