Need help. Multiple issues w/ 1992 standard Honda accord
Old Feb 16, 2010 | 10:09 PM
Fayrow's Avatar
New User
Default Need help. Multiple issues w/ 1992 standard Honda accord
I have a 1992 Honda Accord stick-shift.
Where to start:
For months, my honda has had a bad fuel injector. It is hard to start at first, but after a few attempts and some revving, the car starts and runs perfect. I tried to use Seafoam but that made the situation worse. Also, the fuel injector makes a high pitch squeal whenever the car is running when my foot is not on the gas.
Also, recently my car overheated. I pulled over as soon as I noticed and then saw that there was white smoke coming from the hood. I filled up the radiator after letting the car cool down and drove it about 2 miles. I noticed that my car's top speed is now about 50 mph, and that it doesn't run smoothly. It runs like a novice driving a stick shift. Also, acceleration is very weak. It seems rpms and mphs go up very slowly.
I checked the transmission fluid and it is brown. Also, the radiator fluid leaks really fast.
Any help is appreciated.
Old Feb 17, 2010 | 07:34 AM
Heat's Avatar
Default Re: Need help. Multiple issues w/ 1992 standard Honda accord
How many miles are on the car and how did you check the transmission fluid? Did you drain it and refill it?
Old Feb 24, 2010 | 12:07 PM
Fayrow's Avatar
New User
Ok, almost everything has been taken care of. I replaced the coolant senser and one of the hoses.
Car starts on first try now. Even so, it does not start overheating. I turn it off though because it seems the coolant hose that attaches at the back of the engine is leaking from where it attaches to the engine. It's leaking considerably.
I do not have another one of those hoses(this is not the hose that I replaced). Is it ok just to cut the tip off the hose and reattach it?
Also, someone I told said it might be a head gasket problem, causing pressure and pushing fluid out. Is this likely the case? My car does not have any white smoke now, and it never had any from the exhaust. The hoses of the radiator are all holding pressure (except the one leaking).
Old Mar 2, 2010 | 02:05 PM
Fayrow's Avatar
New User
I'm oh so close now. I have replaced the hose, so now I am not losing any coolant fluid.
For some reason, my car is overheating. Also, after the engine starts to warm (20 minutes or so), the acceleration loses power. The engine only seems to heat up when accelerating or when going up a hill. The car seems to idle fine. Whenever the car is stopped, the heat drops way down.
Sammie Brooke
May 3, 2018 09:59 AM
Elac
Dec 29, 2014 05:57 PM
clifftbrd
Jul 11, 2014 01:40 PM
pdxaccord
Oct 8, 2007 06:59 PM
honda_accord_215
Sep 14, 2005 04:23 AM
