'00 V6 Accord Gauges not working
Old Feb 16, 2010 | 04:30 PM
coupegirl66's Avatar
New User
Default '00 V6 Accord Gauges not working
I started my car this afternoon and none of my gauges worked??? Gas gauge, rpm, and temp. By the time I travelled the mile home, they all were working. Car seemed to run normal the whole time.
Any suggestions???
Thanks!
Old Feb 16, 2010 | 04:55 PM
redbull-1's Avatar
Default Re: '00 V6 Accord Gauges not working
Any modifications done to the car?
Even though your gauges did not work at first, did other instrument panel lights come on for at least a few seconds when you started the car?
Old Feb 16, 2010 | 05:07 PM
New User
Totally stock
Everything else worked fine. All the lights that normally come on when you start the car came on as far as I noticed.
Old Feb 16, 2010 | 05:17 PM
redbull-1's Avatar
Hopefully, this was only an "intermittent failure", which Honda means there was a failure; but, it checks okay now. Hope it doesn't occur again.
If it occurs again, the normal procedures are check wires, connections, and fuses (blah, blah, blah). See link for cluster removal: http://www.ledautomotive.com/guide.php?id_cms=22
Worst come to worst, it may be the printed circuit board (combination) # 13 in this image. As it is expensive from Honda, you can get a used one to replace. But, your odometer reading will not be the same, as the odometer is part of this board.
Rotting Prelude
Oct 21, 2016 01:00 PM
Callas52
Honda Civic (2001 - 2005)
Jul 2, 2014 12:25 AM
solidsnakex37
Apr 16, 2008 02:28 PM
all420
Feb 2, 2005 10:20 AM
