B20B into 1990 Integra question
Old Feb 16, 2010 | 02:17 PM
DumaDA's Avatar
Default B20B into 1990 Integra question
I recently swapped a jdm b20b into my integra which is obd0. I used my stock ecu and harness, i noticed that there is two plugs with no where to go hanging in the back of the head. The motor starts up fine and idles ok, hasnt been fully test driven yet. Am i going to run into any problems because of these 2 plugs or should it be fine? There is no CEL also
Old Feb 16, 2010 | 03:18 PM
jasperdeea90's Avatar
Default Re: B20B into 1990 Integra question
I got this one
I believe one of them is for a knock sensor/no worries-
Are the wires together?pics?
The other may be for your fan? did you run it for a lil bit and see if your fan came on? i had to modify mine for it to work, and it's in a 90 da chassis..
I've found it easiest just to wire it up to a switch
Old Feb 16, 2010 | 03:23 PM
DumaDA's Avatar
thanks man, i dont have pics yet but im sure it'll be fine, if anything i might wire my fan to stay on 24/7 just for cooling purposes
Old Feb 16, 2010 | 03:29 PM
no prob hoped that helped..i been there btw, you're gonna LOVE that torque anything else lemme know
I would advise not to have the fan on 24/7 unless you plan on changing your
engine bays color to charcoal,lol..from what i've seen up to a switch with a 30amp inline fuse if perfect
Old Feb 16, 2010 | 03:36 PM
DumaDA's Avatar
yeah cant wait to see how it goes, i also put in a ys1 gsr transmission with a stage 1 exedy clutch and 8lb fidanza flywheel, removed my a/c, cruise control, and power steering. Should be fun haha
Old Feb 16, 2010 | 03:52 PM
Gsr trans huh? ganxta! right on getting rid of all that useless weight sir
I sense a full wire tuck in your future,haha..been watchin' your progress since the beginning, good shyt there man is it just for street duty? or you got other plans....
Old Feb 16, 2010 | 04:01 PM
DumaDA's Avatar
well im probably just going to leave it like this for awhile, im expecting a kid in not too long, i'll probably go b20vtec once i get bored of the current power haha
mauirixxx
Nov 17, 2011 09:24 PM
boostNjuice
Aug 21, 2011 11:56 AM
Racing Mom
Jun 10, 2009 02:20 PM
j_kevin_ca
Jun 5, 2007 10:41 PM
scrubachu
Aug 28, 2004 07:21 AM
