Transmission & Drivetrain Gearboxes, Differentials, Clutches
Wear on D-series '96 - '00 Steel Forks
Old Feb 16, 2010 | 02:09 PM
94EG8's Avatar
Seagull Management
Default Wear on D-series '96 - '00 Steel Forks
Anyone expirenced any unusual wear on D-series 3/4 '96 - '00 Steel shift forks? I've taken apart 4 of these things, and every one has a worn out 3rd/4th shift fork, not bent or broken, just worn way past the service limit where it goes over the slider. I don't know if I just got 4 bad ones in a row or if it was common. Other 2 forks were always fine. I ended up welding on one and filing it flat to build it back up again because I couldn't seem to find a good used one anywhere.
Old Feb 17, 2010 | 01:29 PM
94EG8's Avatar
Seagull Management
Default Re: Wear on D-series '96 - '00 Steel Forks
Anyone? Anyone? Bueller?
No one has ever seen this before?
Old Feb 17, 2010 | 06:19 PM
Aquafina's Avatar
Part of it is due to the slider design, part due to the driver.
Not everyone I've torn down is bad.
Old Feb 18, 2010 | 03:58 PM
94EG8's Avatar
Seagull Management
Thanks Aquafina. I have to say i'm a little surprised, The one '92 - '95 tranny I built had perfect shift forks in it, i'm not sure if it was low mileage or if the aluminum forks just didn't wear all that much.
Old Feb 20, 2010 | 08:18 PM
Mista Bone's Avatar
D Tranny Guru
Where are you taking the measurement????
Old Feb 21, 2010 | 06:34 AM
94EG8's Avatar
Seagull Management
I remember I checked with a feeler gauge between the fork and the slider. I can't remember for sure if I measured the fork thickness with a vernier scale or not. It wasn't something you had to measure, there was about a 1/16" of play, you could see where the slider cut deep into the fork.
bluelights81
Jan 15, 2014 10:39 AM
Jap_Spec_Imports
Mar 15, 2009 01:26 PM
clem kevin
Feb 11, 2007 10:50 PM
AsianMullet
Nov 15, 2003 12:37 PM
