convert seatbelt
Old Feb 16, 2010 | 02:18 AM
whyS0serious's Avatar
Default convert seatbelt
Hi there guys just wondering if there is a howto/DIY guide to convert 90-91 seatbelts to 88-89 seatbelt since I hate having the belts on the door plus i had an incident when the belt didn't retract and when the door close that metal part of the belt got stuck and made a big dent between the door which really sucks
ps. I used the search bar too
Old Feb 16, 2010 | 06:29 AM
Crx_JDMWhore's Avatar
Default Re: convert seatbelt
thats sucks, i think you should bail on the seat belts and get a pair of racing seats and racing seatbelts!!
Old Feb 16, 2010 | 06:56 AM
k20rex's Avatar
you could buy a 88-89 just a thought
Old Feb 16, 2010 | 07:52 AM
xnsxcrx's Avatar
look in the civic/crx faq 2.0, your going to need seatbelts out of another car with pillar mounted seatbelts, I was going to do it but it requires a bit of cutting and welding.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-seat-belt-conversion-write-up-door-pillar-1456104/
Old Feb 16, 2010 | 11:39 AM
https://honda-tech.com/forums/showthread.php?t=1456104
dammit nvm.. lol if there weren't any cutting or welding i would of done it but hey thanks for the url
Old Feb 16, 2010 | 12:01 PM
xnsxcrx's Avatar
no problem, yeah cutting and welding is the only thing that turned me away from that project, maybe later on down the road, although 5 point seatbelt harness is an option too if you dont like the door belts
Old Feb 16, 2010 | 03:40 PM
Ldo's Avatar
Ldo
What cutting?
The only cutting I can think of is drilling or enlarging the holes to drop the nut in. A little dremel or drill bit can do that in 2 mins. If you think that's too much cutting, then you shouldn't own a 20 year old car or work on it at all
As for welding, you can just weld the nut onto a thick washer (both are available at Home Depot) and weld that washer onto the pillar. You can drive your car to a shop with a welder and pay them $20 to weld in 3 spots. Take them about 10 mins to do.
Get those door mtd seatbelts outta there!
stegs
Apr 2, 2008 04:36 PM
streetsold6teeny8
Feb 28, 2006 10:33 AM
VeilSide_Mas
Dec 4, 2005 01:30 PM
drvfast
May 2, 2004 05:09 PM
crashtest Sonny
23
Jun 3, 2003 12:30 PM
